Results 1 to 6 of 6
    Active Member tnhoover's Avatar
    Jul 2010
    York Pa
    Default Bumpskid LED lights
    Looks like I either messed up the light by running over something or someone bumped it when I wasn't around. Either way the question is can I somehow fix these or do I need to buy a new light strip?
    I'd contact Harvey about it, and see what he says...
    Good luck!
    Active Member Doc - Riverside's Avatar
    Jan 2010
    USA Folkston,Ga
    Quote Originally Posted by tnhoover View Post
    I will bet if you turn the key on and then gently press in on the area by the last lit LED the rest will come on. The problem is they tack soldered LED strips together with the new lead free solder which can't handle vibration to well so the joint failed. This is a manufactured defect when they put several strips together before they put the clear urethane coating on it.
    Harvey has switched suppliers; once this defect was known to him...
    Very Active Member jtoro1's Avatar
    Feb 2013
    port st lucie fl
    Default LED strips
    You have to be a surgeon to be able to solder it together I would suggest buy a new LED strip I fixed it once and it failed again in another section they're too delicate for the vibration but I love the lights
    Very Active Member DJFaninTN's Avatar
    Sep 2013
    Panama City Beach, FL
    Harvey will do you right on it I'll bet
    2015 RT Limited Intense Red Pearl
