Results 1 to 11 of 11
Thread: Oil Change Kit
    Very Active Member rcturner's Avatar
    Jun 2012
    Fairmont, Minnesota
    Default Oil Change Kit
    Today, I changed oil in my 1330 for the first time. I went slowly and took my time so that I could learn as much about the machine as possible. It was significantly different from the 998. I am not sure that I would consider it to be any easier than the 998 but, all went well. I used the new oil change kit and all was good except there was no copper washer ( PN 420250640 ) for the gear box drain plug. Is this normal or was mine missing something ?
    Jul 2014
    Mint Hill, NC
    Based on watching Shawn Smoak's 1330 oil change video I'd say you got shorted. He showed the contents of the kit and everything necessary was there.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Active Member JIM W's Avatar
    Mar 2016
    Howard's Grove WI.
    One of the washers is silver in the kit that I purchased
    Jul 2014
    Mint Hill, NC
    The silver (aluminum) one is the engine drain plug washer.
    Cognac 2014 RT-S
    Jun 2012
    Fairmont, Minnesota
    Mine did not have the copper washer. The aluminum one was there but, as stated, it is not the one for the gearbox drain plug. Next time I will have to check before I bring the kit home.
    Sep 2013
    Houston
    Or you could just order the kits from BajaRon for less money and let him check the contents before he sends it to you. I find it far easier than dealing with a dealer parts jockey and making multiple trips for overpriced parts.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Jun 2012
    Fairmont, Minnesota
    I have no complaints about my dealer any how they treat their customers. I would not have any reservations about ordering from BajaRon but, this was it's first oil change and I have always felt that not creating a situation that could put me or the dealer in the position of having to defend my actions is prudent just in cast any issues are uncovered.
    Jul 2011
    Cleveland, Ohio
    Could not find the kit, could you give me a "link".
    thanks Chris
    Sep 2014
    USA
    Quote Originally Posted by No 2817 View Post
    thanks Chris
    . Click on home then look for Baja Ron on the vendor page
    Nov 2011
    Default oil change kit
    How many quarts did you put into the bike?
    Jun 2012
    Fairmont, Minnesota
    Quote Originally Posted by spyder stryder View Post
    About 5.3 qts. It registers full when hot.
