Results 1 to 19 of 19
    Sep 2012
    Stetson, Maine
    Default Finless Bob, Question
    Bob, the front tires that you put on your Spyder are General Altimax, 185/60/R14. In your video you mentioned T-42, I believe. Could they be RT 43? Thank you. Bruce
    Default RT 43
    Quote Originally Posted by safecracker View Post
    Bruce I am familiar with that tire and Yes, the General Altimax is an RT43............Also it has the highest performance ratings for tires we can use .......Mike
    Jun 2010
    Las Vegas
    But they don't make one to fit the 15" rims.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Sep 2012
    Stetson, Maine
    Thank you both for your responses. Bruce
    May 2013
    Stanton, ca
    Looks like you got your answer... Sorry I was not online last night.
    Bob
    Sep 2012
    Stetson, Maine
    Thanks Bob. I ordered tires thru Amazon. $68.32 a piece. Free Shipping.
    Sep 2012
    Stetson, Maine
    I got the tires mounted and installed (fronts)on the Spyder today. Have not had a chance to try them. I am sure they will work great. Bruce
    Apr 2016
    Lancaster, PA
    Default Speed off?
    Bob, when you put the general tires on and different size from original did you notice your speedometer reading different from actual speed and if so how much?
    Thanks
    Nov 2012
    North Las Vegas, NV
    Quote Originally Posted by Wfreysr View Post
    Thanks
    Fronts don't have anything to do with speed, it's read off the rear tire. To make the speedo accurate I use a 215/60/15 tire on the rear.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    May 2013
    Stanton, ca
    Thanks
    Nope as highwayman said speed is read from the rear. But be aware that if you change too much you "might" upset the nanny (especially if your rear is different too) so I went with a size/tire that people had used before.
    Bob
    Very Active Member robmorg's Avatar
    Oct 2013
    Pottstown, PA
    Default Another Tire Question for finless..
    Here's another tire question for you, Bob. What do you think of the Yokohama sDrive that you put on the rear about a year ago? You've probably got several thousand miles on it by now, so I'm wondering about your impressions.
    Rob
    2013 RT Limited
    My "Mods & Farkles" Link
    May ALL your roads be beautiful
    Greisemer's Mill Bridge, Oley, PA
    2013 RT Limited , Lava Bronze with Antler Brown Seat
    May 2013
    Stanton, ca
    Quote Originally Posted by robmorg View Post
    Still liking it. I put it on at 13K miles and now have almost 21K. So 8K on it and it is still looking very good! I will probably get 14K total out of it maybe even more.
    Since you asked here is a picture of it taken today.
    Bob
    Oct 2013
    Pottstown, PA
    Thanks for the picture. That tire DOES look good for 8000 miles. I like mine too. Mine's got less than half of that, but it still looks brand new, and it runs in the rain just like it was on dry pavement. I'm staying with the Yokohama when this one finally does wear out.
    Rob
    2013 RT Limited
    Devine, Texas
    Default What size Tire?
    Quote Originally Posted by finless View Post
    Bob
    What Size Yokohama sDrive did you put on?
    Apr 2016
    Lancaster, PA
    Bob
    Finless, I'm looking at replacing my fronts on my 2011 RT with the same Altimax's.
    what mileage do you expect to get from them and would you by them again?
    thanks Wes
    (Off-Topic)
    That belt alignment looks pretty darn good too!
    May 2013
    Stanton, ca
    thanks Wes
    Well I expect to get a lot more miles on them than I did the stock tires which actually did well (22K and I only replaced them because they went out of balance real bad).
    I have only had these new altimax fronts about 2 months now so not a lot of miles on them yet.
    I do like them so far.
    Bob
    May 2013
    Stanton, ca
    (Off-Topic)
    Darn good? I would say perfect! I have it at 2.5mm which is almost dead center of the spec
    Bob
    Apr 2016
    Lancaster, PA
    Default Thanks finless
    [QUOTE=finless;1172741]Well I expect to get a lot more miles on them than I did the stock tires which actually did well (22K and I only replaced them because they went out of balance real bad).
    Bob[/QUOTE
    Thanks Bob, appreciate your response. Going to get my alignment and order a new set of the Altimax's. From what I read about the positive results using rideon balancing / sealer I plan to order that and put in to balance. Looking to change the tires off the rims myself.
    Always appreciate your input when I read these posts.
    thanks Wes
