Page 2 of 3 FirstFirst 123 LastLast
Results 26 to 50 of 54
  1. #26
    Thanks for the update, although I'm sorry to hear that you're still in the middle of this mess...
  2. #27
    Active Member JIM EVANS's Avatar
    Sep 2014
    GAFFNEY SC
    SO I NOW ALSO HAVE A NEW WIRING HARNESS IN THE BIKE AND IT IS STILL NOT CORRECTED
    WAITING FOR BRP TO CALL ME AND GIVE ME AN UPDATE
    JIM EVANS
    2014 RTL, cb,all panels color matched over 300 LEDs, pass armrests sat radio chrome WS brkt, larger w.s, more to come
  3. #28
    Sep 2014
    GAFFNEY SC
    so brp called last night... sending new main harness now shop wont get it till Friday so another week and weekend without bike.. I have to laugh tech manager told me maybe it was my led lights causing the problem.... right on a separate circuit not spliced into any harness of the bike totally separate wiring no switches on bike controlled by keyfob and was the first thing disconnected he then said maybe it was the battery tender hook up seriously.. If a battery tender connected directly to the battery can cause this you have more issues than a battery tender.. also then why was everything just fine for almost 2 years with no issues... anyway new harness will be here Friday.. asked what happens if this doesn't fix it,,, as i have been told 5 times this should fix the problem.. he said would have to likely replace bike... also explained to him that the only thing plugged into the main harness is the can am cb unit...
    the saga continues
    JIM EVANS
  4. #29
    Especially about treating the technicians as if they are your new Best Friends...
  5. #30
    Sep 2014
    GAFFNEY SC
    AH THE TECHS ARE FINE.. SO BRP SENT A NEW MAIN HARNESS TO THE SHOP AND THEIR TECH TEAM LEADER CALLED ME.. SHOP EXPRESSED CONCERNS ABOUT INSTALLING HARNESS TIME WISE AS SHOP IS BUSY WHICH I TOTALLY UNDERSTAND TO WHEN BRP CALLED I TOLD THEM ABOUT BARBWIRED INCIDENT SOUNDS THE SAME AS MINE PARTS AND ALL.. SO TOLD THEM WHY DONT THEY CALL THE DEALER THAT DID HIS BIKE GET THE VIN LOOK UP TO SEE IF THEY DIAGNOSED HIS OLD HARNESS TO SEE WHAT PIN OR PINS WERE BAD AND IF THEY DID DEALER COULD JUST REPIN THE BAD ONES AND POSSIBLY FIX WITHOUT INSTALLING HARNESS IF THAT WOULD FIX IT... SO THEY ARE GOING TO DO THAT AND IF THEY HAVE TO REPLACE HARNESS
    THEY ARE GOING TO SEND SOMEONE FROM BRP FULLY TOOLED TO GO TO THE DEALERSHIP AND DO THE INSTALL , AND IF THAT DOESNT WORK LOOKS LIKE THEY WILL BE SWAPPING ALL THE PLASTIC AND ACCESSORIES TO A NEW BIKE AS THEY ARE BAFFLED.... THE ONLY THING THAT WONT BE ABLE TO BE TRANSFERED THEY WILL NOT BE ABLE TO DO THE ALIGNMENT AND I WILL HAVE TO REINSTALL MY LED'S OH WELL NEEEDED A WINTER PROJECT
    MORE TO COME
    JIM EVANS
  6. #31
    Default YOUR ISSUES
    Well it certainly appears both BRP and your Dealer have stepped up to the Plate for you ..... good luck .....Mike ...........................PS thanks for keeping us in the loop
  7. #32
  8. #33
    Sep 2014
    GAFFNEY SC
    They do need to do something it has been six weeks. We both want to avoid the lemon law stuff so we shall see what next week brings
    JIM EVANS
  9. #34
    Very Active Member Tango's Avatar
    Apr 2012
    Florida
    Wish we had a motorcycle "Lemon Law" here in PA.. I looked into it. They say there is something else they can do. TOM
    Baloo is my name. Spyders are my game. Well, it's a doo-bah-dee-doo, yes, it's a doo-bah-dee-doo, I mean a doo-bee, doo-bee, doo-bee, doo-bee, doo-bee-dee-doo. And, well, now. Ha ha! What have we here?
    2020 Petrol Blue Metallic RTL
  10. #35
    Active Member willey's Avatar
    Jul 2013
    martinsburg,ohio
    Default purge valve
    my 2013rts was acting a lot like yours.i saw on this form that it could be the purge valve.i asked the dealer to check the valve,it was stuck open.he installed a new valve,20,000 miles later and still runs like new.
  11. #36
    Jul 2014
    United States
    Quote Originally Posted by JIM EVANS View Post
    just to keep folks informed bike is still in the shop going on the 6th week.
    it is frustrating as no one at dealership or the tech gurus at brp can figure out the problem so Friday they overnighted new coils, plugs and wires and a new wiring harness to the dealer
    dealer was instructed to install new plugs wires and coil packs now we had already replaced the same things on one cyln in the second week , told the team leader and customer service manager don't think that will fix the problem alas yesterday afternoon they were installed and no change.
    so to finish out their day yesterday the dealer started the process to replace the wiring harness and team leader at brp told me will have an answer from that process by 1pm today.. I hope this is the issue as I have had the discussion with brp about replacing the unit at lemon law in ct is 30 days in shop for same problem as stated going on 6 weeks now.
    don't really want to replace the unit with all the custom paint and accessories as if they replaced the unit would have to switch all plastic and accessories cb, chrome etc..
    so hoping that there is an electrical issue in the harness as engine is sound with no issues
    so here is what has been done
    4 spark plugs
    4 wires
    4 coil packs
    fuel pump
    main computer
    computer resets, hystest valve checks, clyn compression test elec system tests and prob even a colonoscopy
    the brp folks have been nice and understanding but if this latest stuff doesn't work I believe more drastic measures are going to have to proceed
    the good thing is I have direct contact numbers and emails for actual humans that have some decision making authority
    Not sure if this is your problem, but a lady that was at a recent rally was going through a one cylinder misfiring and after much parts replacements and reflashing they finally found that the injector wiring harness had shorted out on one of the cylinders. Might suggest that they check them. Especially since you were smelling gaas. Good Luck!
  12. #37
    May 2012
    pa
    Do the Lemon Laws apply to motorcycles in your State?
    Not in Pa. Spend $30,000 and not covered.
  13. #38
    Sep 2014
    GAFFNEY SC
    Thanks they did the engine harness. Reset valves so we will see what the brp tech can do with the main harness
    JIM EVANS
  14. #39
    Active Member spyderryder53's Avatar
    Jul 2014
    Hanover CT
    Default 6 weeks wow
    Hi Jim I just noticed this , I was wondering why I haven't seen you here looking to see if anyone was going for a ride .
    Hope you get your bike back for spyder quest .
    Leon
    2022 marsala red RTL
    AND
    2014 RT S SE-6 COGNAC, 2010 RT 622 TRAILER TIMELESS BLACK
    BRP trailer hitch, Utopia back rest, Baja Ron sway bar , heim links. Elka stage 2 shocks front and rear.
    TricLed fender lights, saddlebag lights and mirror lights. LED headlights and fog lights, Wide vu mirrors.
    spyderpops LED bumpskid ,zippered cargo bag linings, Laser Alignment by Netzleys Tire, Stebal air horn
    stant gas cap,( Dimple oil plugs REMOVED ) JT dash mount.
    (Onboard) Lamonster Garage air compressor and intelliboost charger.
  15. #40
    Sep 2014
    GAFFNEY SC
    It has been an adventure Leon
    JIM EVANS
  16. #41
    Sep 2014
    GAFFNEY SC
    SO TODAY A PRODUCT SPECIALIST FROM BRP WENT TO THE DEALERSHIP... WE WILL SEE IF HE CAN FIX IT.. I HAVE MY DOUBTS HOPE I AM WRONG..
    JIM EVANS
  17. #42
  18. #43
    Sep 2014
    GAFFNEY SC
    OK so can am sent their product specialist down to the dealer from Canada. He spent about 8 hours checking every wire in the harness. All OK he then rechecked all the engine and computer functions. Compression fuel all good. Should run. Today around one PM got the call from my brp contact in Wisconsin. Needs a new engine. Went to dealer. Eric brp tech took a horoscope thru the intake to the second cylinder. It looked like an explosion of metal. Something a valve seal or something let go. Believe it or not due to a previous mixup with ae f3. And no one returning an engine that was sent to the dealer a little while ago. The engine is on stock and will be installed next week...... Brp is shipping my engine back as they need to know what failed and the engine builders in Austria are. Curious Also. It was a long journey but at last they found the problem. Thanks to my dealer Columbia Motorsports. Eileen at brp for talking to me and keeping me informed and speaking to me almost every day since the case got elevated to her level. Joseph a team leader for the techs. And the last one to get involved Eric he is the Spyder guru product specialist. It Eve had him perplexed. The one thing he did say is that when he gets involved. He rechecks everything that the techs at the dealership does and the reports they send to brp. As he said some get lazy happy to say that was NOT the case here. Glad to hear that as the owner is a personal friend . so hopefully will be back riding next weekend
    New parts
    Engine
    Fuel pump
    Main computer
    Engine harnesz
    Plugs
    Injectors
    Coils
    Wires
    Almost 8 weeks of dianostics
    JIM EVANS
  19. #44
    Apr 2012
    Florida
    All I can say is, WOW! Glad it will all work out for you. Tom
  20. #45
    Jul 2011
    Mitchell, Ontario, Canada
    I am glad to hear the light at the end of the tunnel is not a train. Thanks for sharing what they found and sorry that it has taken this long to find the problem.
    2018 F3 LIMITED
  21. #46
    on the fact that they found the problem, although I'm sorry that you've had to endure so much...
    Why not ask if they'll throw in an extended warranty on your bike, as a gesture of good faith?
    It can't hurt to ask!
  22. #47
    Sep 2014
    GAFFNEY SC
    Well over eight weeks new engine seems to have fixed the problem. Liked up this evening. Will be putting it thru it's paces this weekend.
    JIM EVANS
  23. #48
    Jul 2014
    United States
    Wonder if a simple compression check would have identified the bad cylinder? We do that on cages all the time. Might just ask if they had done that and if not, maybe they should add that into their diagnostic flow chart. In reality it only comes down to three areas: mechanical, electrical, fuel. Sounds like they concentrated on just the fuel and electrical and left out testing the mechanical. If BRP is smart they will learn from this mistake. I bet it cost them many thousands of dollars in labor and unnecessary parts.
    And the sad thing is: they had the plugs out, they could have run a compression check and/or a borescope then. Harbour Freight sells borescope cameras for under $100.
    Glad they found it and congrats on all the new parts, even an engine!!
  24. #49
    Sep 2014
    GAFFNEY SC
    They did compression and leak down the first week. All were normal
    JIM EVANS
  25. #50
    Jul 2014
    United States
    Hum, with it that damaged you would have thought the compression would have been lower in that cylinder. And with good compression I would not have bore scoped it either. Certainly food for future thought and I hope this was a fluke. The 1330 triple is an awesome engine and other than a water pump failure it seems to be almost bulletproof.
