Results 1 to 10 of 10
    Very Active Member Rogue Hawk's Avatar
    Apr 2015
    Chicago
    Default how do I get this panel off?
    The one circled in red. The guy who worked on my bike hide my power cable to heat my electric gear behind this panel.
    2019 Rally , Black
    Nov 2013
    Central Texas
    Have the guy that worked on it take it off & put your wire back in its correct position. For free.
    Feb 2016
    Florida
    The panel with screws in front of it has to come off first, then behind it you'll see the scores hold the panel you want remove.
    Bossier LoUiSiAna
    Quote Originally Posted by oldguyinCT View Post
    I hope all that he did was tuck it in hidden!
    Apr 2015
    Chicago
    I would its pretty far away and its too cold to ride without my heated gear. Next week should be better.
    I also want him to look at the heated grips he put in. They only get hot when the bike is moving, then cool off when I am stopped at a light. The problem is I don't have a ride to and from the dealership. I paid for a cab once, but it was $50.
    2019 Rally , Black
    Default There is a sequence...
    mostly the panel above the one you want comes off first and then the one you need to remove.... have you checked that the cable is reachable from under the seat..? just wondering on mine (RS) it is under the seat....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    May 2009
    Connecticut
    There is a auxillary power outlet under the seat- I attached my controller for my glove liners under the seat and then attach it to Velcro along the side of the frame when I want to use it!
    Sea Doo GTI-SE 90 Jet Ski!!
    Apr 2015
    Chicago
    I really don't know how its attached. When I take the seat off I don't see the wires. I would like iMotorsports to look at a few other things. But since I don't have a ride, its expensive for me to leave it there. The cab is $50. Perhaps I can get iMotor to take me home if I pay them.
    2019 Rally , Black
    Very Active Member Wiredux's Avatar
    Aug 2012
    Jacksonville, NC
    Quote Originally Posted by Rogue Hawk View Post
    You will have to remove the seat as well as the forward panel. Only 4 screws and 2 bolts to get to the rear panel. Once you have access to it, just unscrew it and there is a tab that will have to be pushed in to remove it. Be careful with the tab.
    Apr 2015
    Justice Illinois
    How far from Imotors do you live
