Results 1 to 24 of 24
    Mar 2016
    CT
    Default Installing the Baja Ron Sway Bar on a 2015 RT
    Hi, I'm the new owner of a 2015 RT Limited.
    I've been reading about the Baja Ron Sway Bar and the ROLO system laser alignment and that they can improve the ride and handling of the bikes.
    Is the Baja Ron Sway Bar something an average DYI guy can install and are there any special tools needed?
    Oct 2015
    miNNESota
    Easy to do as long as you have the means to get the front end about 2 feet off the ground to get the old bar out and the new one in.....
    2019 900 Rally , Black
    Very Active Member Devious56's Avatar
    Oct 2015
    N.E. Florida
    Yes, the hardest part is getting the front of the spyder high enough to get the old bar out and the new bar in. 22 inches is recommended, but that is only remove and install the bar, everything else can be done with drive on ramps about 10 inches high. The bar will come with great instructions, just read and understand them before you start.
    David
    How old would you be if you didn't know how old you were?
    Dec 2014
    Lee's Summit, MO
    Not bad at all to change out. I used two motorcycle/atv lifts. One under each front tire. Took me about an hour and fifteen minutes start to finish. Take your time and work safely.
    Mar 2016
    Akron,Ohio
    Default Sway Bar install
    I just installed Rons sway bar on my 2015 RTL today. His directions are fantastic. I used car ramps with two inch blocks under ramp. Used a floor jack to go up high enough to get the old bar out and the new bar in. Lowered it back on the ramps and finished the job. Wasn't to hard at all!!
    Default Yes...
    Diy'fers can do this with the instructions provided...you need to be those that read instructions. . but as mentioned above the height is the tough part...
    Oct 2015
    Townsend, MASS
    What is the advantage of putting the new sway bar on a 2015 RT? I have seen it come up again and again, but my bike seems to handle fine to me. It may be me still getting use to the difference from 2 wheels to 3.
    Apr 2014
    Hershey, PA
    Quote Originally Posted by Big Will 51 View Post
    I thought the same thing! You can't explain the difference, but, it is AMAZING!! The ryde is nice before you get it, and incredible with the new sway bar. Just added one on my 15 RT limited last week!
    Apr 2014
    Hershey, PA
    Quote Originally Posted by DanT View Post
    Took mine to the dealer...1/2 hour and we were out the door!
    Saved the hubs from trying to balance my bike on some contraption and my nerves helping him!!
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by Charlotte17078 View Post
    I get a lot of calls asking me to explain exactly what the sway bar does for the Spyder. And you're right. I can give you all kinds of technical data of exactly what the bar does. But all of that doesn't get the true effect across. But as soon as people get a chance to ride the bar. Their eyes light up and they go 'AH! Now I understand!
    It's so much fun to see that look of comprehension.
    Thanks everyone! You all do a better job of explaining my bar kit than I ever could! Enjoy the ride!
    Aug 2015
    Afton Tn.
    Default Spot me on an IBA ride
    look like it be easy job
    Oct 2015
    miNNESota
    Someone told me that the 2016 RT has a larger Sway Bar than the 2015's...... Is that true?........
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by vstrommer View Post
    Sorry, not true. Same bar.
    Dec 2014
    Lee's Summit, MO
    I rode last season completely OEM. I installed Ron's sway bar in early March and the shock adjusters three weeks ago. Made my RTL a completely different ride for the better. It handles the the curves like I'm on two wheels. Makes a big difference in the wind. The shock adjusters have got front end off the ground, which is really nice when I am running the old county roads. The shock adjusters have also cut down on thpe brake dive. I can not even think of going back to OEM.
    Jan 2015
    Flint Hill VA
    Baja Ron's instructions are great. Easy install and while you have the RT off the ground, install a bumpskid from Spyderpops.
    Apr 2015
    Chagrin Falls, Ohio
    About lifting the front end, my driveway has about 18" wide drain. Position bike over drain and it made it easy to install sway bar.
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by Jfhaas View Post
    Should I add this one to my instructions? I can see it now. Spyder owners riding around looking for storm drains with a bar kit in one hand and tools in the other!
    You all come up with ideas that I'd never have thought of!
    Apr 2015
    Chagrin Falls, Ohio
    Remember the old pits in some garages. Had one in our first house and that gave me the idea.
    Sep 2009
    La Valle, WI
    Is the bar pronounced BA JA OR BA HA Just wondering.
    2018 F3 Limited , Oxford Blue
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by JP58 View Post
    It is pronounced BaHa. But spelled BaJa. That is because Baja is Spanish. And in Spanish the 'J' carries the English 'H' sound. I'm sure that clears it all up for everyone!
    May 2015
    Lynnwood, WA
    And after you install one you can't help but yell "YEE-HAH!" due to the handling improvements.
    SpyderLovers Sponsor spidergreg's Avatar
    Sep 2015
    Jamestown, KY
    Default Actually...
    Quote Originally Posted by Shiznit98204 View Post
    wouldn't that actually be YEE-JAJ!"
    Greg and Debbie 2012 RTS
    Our Mods
    Jun 2015
    Midland, TX
    No Engleesh!
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by spidergreg View Post
    I was going to say this but I thought better of it. But I'm really glad that you did!
