Confused
Does anyone know if the F3 "Attitude" handlebars are the same as the closest (to the rider) holes on the uFit systems at the dealers?
no
they have you lean forward slightly and the grips are angled rather than the "straight across" grips on the standard bars.
We now have His and Hers Spyders!
Current Spyder: White 2015 F3-S SE6
His Spyder: White 2015 F3 SE6
Previous Spyder: 2012 RT Limited SE5 -- 30,300 miles
Previous rides: Kawasaki & Honda
I bought a set of Attitude handlebars and there is for me a major problem with them. The bars on full lock touch the fuel tank paintwork and may/will mark it over time. I took mine off and reverted to stock.
Excuse my ignorance but
Couldn't you loosen and raise (tilt) them a bit to clear the tank?
Try rotating them in the clamps.
The Attitude bars look as if they've got more "sweep" to the bar ends. They're definitely not as flat as the other choices.
You have very minimal movement to rotate them as they have a lug that stops them moving too far, and yes they do mark the bike.
I have someone looking at making me a cradle, similar to a riser block to lift them a little
We now have His and Hers Spyders.
Current Spyder, 2015 F3 Steel Black, Passenger Backrest, Blue Ridge Screen with Xcreen Extention, Akrapovic Muffler, Attitude Handlebars, Blades front rims, RT Swaybar,
Her Spyder 2011 Magnesium RSS Sportrack and Backrest, Comfort Seat, Grip Puppies, 3.5 inch Riser Bars, Wespyd Signature Swaybar. Hindle Muffler, Godiva Screen, Hiway Pegs Can Am Panniers
Previous Spyders
2013 ST SM5
2011 RSS
2010 RS
How big is that "Lug"?
Can you grind it off?
cabinet bumpers
I stuck on two small clear cabinet bumpers for where they hit the tank.
And this is OEM for crying out loud. Don't they test their own equipment???? Geezzz!
Sent from my SM-G935V using Tapatalk
I too tried the attitude bars and took them off. Found the lean forward riding position really hurt my neck and shoulders after a while. Putting the stock bar back on felt MUCH better after living with the attitude for a few weeks.
It's all just a question of preference and your size. I'm 190cm tall and the Attitude bars are perfect for me. I tried them with the UFit setup and they instantly felt right. Try finding a dealer who has the UFit and try for yourself.
And don't worry about them touching the tank...they only do a little bit (just plastic on plastic anyway...) and only in maximum steering (which never would happen while driving). I never even realized it until reading the thread!
How do you know on the uFit if it's the attitude setup? Is it the holes closest to the rider?
If I remember correctly, it was the hole the farthest away from the rider... But your dealer should be able to tell you!
I agree. My husband has the standard bars which work great for him, and i have the attitude which are great for me. When we switch rides so that the other person can see their ride, we both get off and go "ick!" because we don't like the handlebar switch
easy reach bars
I,m only short but I was having trouble with my neck hurting with the stock bars after a few thousand kms on my F3s
I purchased the easy reach bars which is closer to me and therefore sits me up straighter,I found this so much better for me,have done 1000 kms with the new bars so all good.
Another thing I did was move the foot pegs forward one notch so my legs are further up front.
Although it feels great,I believe I have lost a bit of control in the corners,not so locked in as I was with standard.
Not going to change back at this stage but something to think about.
The ones closest to the rider are called "short reach" bars (I just installed those this evening, love them so far).
I believe the attitude bars are the farthest holes from the rider.
2015 Spyder F3-S SM6
