Results 1 to 20 of 20
    Bossier LoUiSiAna
    Default How does this attach?
    Ya Fyi just before Easter I was backing into my parking spot & heard a faint scrape sound, (not level ground, but not much incline,just enough to drain rain water) I investigate & find the bottom plate on LH side has come loose? I do not see how to get back in place Know my dealer will fix on my way to spyderfest , still covered with warranty But still wanna know. Also fyi no crazy riding just crappy Louisiana pothole roads, few RR crossings but all at slow speeds
    thx in advance
    Default Let's see....
    Should have a torx bolt in the very front and two up under the center panel and the rear panel. the bottom has a tab that fits under the sub frame. Looks like you popped the tab out from under... now that is for the deflector. the bottom panel has a torx bolt in the middle a tab and two 10mm bolts to the main frame....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Aug 2013
    SF Bay Area
    Pop it off and leave it off. Most of us do.
    Susie - 2013 Spyder ST-Ltd
    Flame Red '04 GL1800
    '97 GL1500
    '95 GL1500
    '89 GL1500
    '83 GL1100
    2021 F3 Ltd , Magna Red
    Bossier LoUiSiAna
    Default Thx
    Guess ill have to get some higher ramps to get a better look. But sounds simple enough. Id rather not take off (just a personal thing )if it is a skid plate they serve their purpose even on the minor things. Glad i spotted & know to be cautious especially in reverse. I may just make early trip to my dealer, nice bbq down the road from them & can get my pre spyderfest readyness service eval instead of last min. Like last year. Thanks again
    Greenville Tx
    Looks like someone may have left out a screw the last time the oil was changed. Im with you though. I dont like the idea of it not being there. Once it is on, it keeps for a sturdier box. Leave one part off and it is much weaker and rattles other things loose.
    2017 F3 Limited
    Dec 2014
    Lee's Summit, MO
    I took mine off and left them off. Makes changing oil much easier and much less messy.
    Jun 2014
    Schenevus NY
    Quote Originally Posted by AY4B View Post
    I see your point but those two panels are much too thin to add anything structurally. They are primarily there for noise abatement. After an incident similar to the OP the left side one on my bike actually cracked in half. I haven't bothered to replace it and when I changed my coolant I removed the one on the right.
    Trb-- (Roger)
    2022 White Pearl F3T
    Spyder States Visited
    Greenville Tx
    Quote Originally Posted by Trbayth View Post
    As long as the panel is not cracked. once it is in place, it adds a huge amount of strength. That is the principle that make L angle so strong. also a fence is much stronger at the corners because you have the strength coming from 2 directions. I tried leaving it off once when I installed my hyway pegs and could tell right away the bottom edge of the Tupperware was going to flop around too much so I put it back on.
    2017 F3 Limited
    Jul 2011
    Mitchell, Ontario, Canada
    The tab for outside attachment point is broke off. Clearly can be seen in the picture. Either need a new one or leave it off.
    Greenville Tx
    Anyone who has ever put together one of those storage sheds in a box will quickly find out that the side walls by themselves will not stand up by themselves, but once the adjoining walls are attached it gets much stronger, and once it is a complete box, It is so strong it can withstand some pretty nasty storms as long as it is anchored down. The Spyder is the same. it is built with some pretty flimsy plastic pieces but once they are all connected it can take you down the road at a pretty high speed.
    2017 F3 Limited
    Greenville Tx
    If that is the case then I would leave it off for now but you can probably repair it. If not plan on getting it replaced at some point.
    2017 F3 Limited
    Jul 2011
    For $17 not worth the effort to try and fix.
    Greenville Tx
    I think that panel can and should be modified to give better air flow and access to the oil plugs without compromising the structural integrity of the lower Tupperware pieces.
    2017 F3 Limited
    Greenville Tx
    It depends on the location of the damage. I can graft on a piece of tydex with some rivets and make it even stronger.
    2017 F3 Limited
    It's easy enough to replace; just call the dealer to make sure that they've got one ready for you!
    Very Active Member 900Dave's Avatar
    Jun 2013
    Fleetwood, PA
    It adds no strength what so ever and serves no real purpose! It is just in the way changing oil. Mine has been off for 18000 miles or so and it will stay off until I trade it for a new F3 Limited. I would not waste any time or money on it.
    2016 Spyder F3 Limited Steel Black Metallic
    Lamonster approved LED Headlights
    Lamonsters LED Fog lights
    BRP Driver & Passenger backrest
    BRP Trailer Hitch
    Shamrock Black & Polished
    Signature light
    Elka front shock's
    Rolo Laser Alignment
    Dual Power outlets
    Garmin 590 GPS
    Dec 2012
    Murphy, NC
    Default PANEL
    While you are at it pull off the bottom right panel also. I took off both panels soon after I bought my '13 ST-S. By doing that it helped dissipate the heat from the engine and made oil changes easier, too.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Mar 2012
    NJ
    The very first thing I did was to pull both of those panels off and toss them in the trash. All they do is collect crap, make it more difficult to change the oil, and make it difficult to do routine spot checks for potential problems.
    Sent from my Nexus 6 using Tapatalk
    Nov 2013
    Oro Valley Arizona
    And remember it's all small stuff!
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Greenville Tx
    Thats what Hillery said
    2017 F3 Limited
