Results 1 to 23 of 23
    Mar 2016
    Akron,Ohio
    Default Ramps for installing Rons Swaybar
    Hi folks, my name is Russ and I am new to this site. I have a 2015 RTL. I ordered Rons Swaybar for my Spyder. I am asking for advice on how you raise up you bike to install the Swaybar. I was thinking the metal car ramps from Harbour Freight. They provide a 8 inch lift. Is this enough? Is there a better way to lift the bike? Thanks Russ
    Active Member vstrommer's Avatar
    Oct 2015
    miNNESota
    You basically need at least 2 feet for sure or you won't get the bar out or in..
    2019 900 Rally , Black
    Aug 2015
    Cleveland, GA
    Default getting it up
    I found it necessary to use a jack stand set on a cement block under each A-frame.
    Jacking it that high in the air before settling it steady on the jackstand/block perch was the scary part. Be sure you have a good ATV jack or equivalent.
    Pete Tamblyn
    Cleveland, GA
    2020 F3 Limited (black)
    Time Out XL1800 cargo trailer
    2019 Royal Enfield 650 Interceptor
    2018 Kawasaki Versys-X 300
    2013 ST (sold)
    2015 F3-S SOLD
    2014 RT-Limited (cognac) SOLD
    Invalid Emails
    Oct 2014
    Calgary, Canada
    I agree with motoswami.
    I used an ATV jack, two heavy duty jack stands and several 2x4 blocks to get enough height to get the old sway bar out.
    Nearly a 30 degree angle!
    It was a scary sight even though I had taken every safety measure imaginable
    Jan 2015
    southern WI
    I set 2" blocks under the back ends of my car ramps and it was enough room for me. Not sure if there's something that different between yours and a 2010. Loosen the frunk and stick a 2x4 between it and the framework and good to go
    2021 RT Limited
    2016 RTS , Pearl White
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by MZEMS2 View Post
    The install on any 2013+ model Spyder is a completely different animal from the pre-2013's. You don't need much height on the pre-2013's. You need 18"~22" of lift on the 2013+ models.
    Oct 2015
    Onebuying
    Default A truck...
    I remember a member stating he used his pickup. Dropped the tailgate and placed two 2x8's as ramps. Drove up blocked the rear tire and sat down to do the deed. I believe there was someone that follow his lead...
    ​2012 RS sm5
    Jul 2010
    Las Vegas, NV
    Default Yikes!
    We use 30 inch tall jack stands. Up 24", plenty of room, safe. I would be terrified of the pickup board trick! No way! My heart skipped a beat when I read that! Joe
    Joe Meyer
    Very Active Member Dan McNally's Avatar
    Jun 2013
    We got my 2013 RT LTD just a bit over 18" to do it - it was tight, but it worked. Used a hydraulic jack at the center lifting point and a pair of jack stands in front. Put the bumpskid on at the same time. A friend did the work and I "stupidvised"
    "Topper" is my Pearl White 2013 RT-LTD
    Professional Retiree - liked it so much when I retired from the USAF, that I started another career so I could do it again!
    Happy to be a member of the Maryland Spyder Web - find us at
    http://www.meetup.com/MarylandSpyderWeb/
    Aug 2007
    Greeneville, TN
    Quote Originally Posted by Hayfield View Post
    Praise the Lord for Friends! (And Supervisors too!)
    Very Active Member Sam Mac's Avatar
    Dec 2015
    Galax VA
    I put my RTL on my lift, set some jack stands under the lift. Then stacked concrete blocks in front of the front wheels. Rolled the Spyder onto the blocks and went to town. I had about 32" of clearance. Overkill, probably but the idea of having fall on me didn't get it.
    Very Active Member bmwlarry's Avatar
    Mar 2012
    Beaverton, Oregon
    Here is what I did.
    2015 an Am Spyder RT Limited
    2013 Yamaha WR250R - Sold
    2011 Can Am Spyder RT-S SE5 Limited - Sold
    2011 Aspen Sentry Trailer
    2003 BMW K1200LT - Sold
    2007 Unigo Trailer - Sold
    2001 BMW K1200LT - Sold
    2001 Honda 750 NightHawk - sold
    2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
    Very Active Member bscrive's Avatar
    Nov 2012
    Ottawa, Ontario
    I did similar to this as well, except I used actual ATV ramps on the back of my 6x10 landscape trailer. My wife's F3 didn't budge at all.
    Invalid Emails
    Oct 2014
    Calgary, Canada
    Quote Originally Posted by bmwlarry View Post
    Here is what I did.
    bmwlarry you used exactly my technique ... right down to the duct tape
    Jun 2010
    Las Vegas
    Do all of the preliminary work with the Spyder lifted at 12" or so, then raise it up to the 24", pull the bar and put in the new one then drop it back down. Especially if you are piling blocks and using other iffy methods.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Mar 2016
    Akron,Ohio
    Default Thanks for the help
    Thanks to all who responded to my request for help!! 2 days ago I took my Spyder out for a 100 mile ride. Damn I really enjoy my bike!! Spyder On!!
    Active Member PatriotRider's Avatar
    Sep 2015
    Metairie, LA suburb New Orleans
    Cool
    on my 2014, I rolled my front wheels up on regular ole car ramps and then set the parking brake. from there, I used a Harbor Freight floor jack just to the (right) side of center of the frame and jacked up the right side and wheel leaving the left wheel still secured against the stop of the ramp. I did follow up the right wheel with a jack stand just in case as the machine went up in the air. the loose old sway bar right end was slid till it rested on the driveway and as soon as the machine was high enough, it just dropped out...I slid in the new one, let the machine down both wheels back on the ramps and then I got under and bolted it up.
    did it all by myself...wasn't the easiest, stress free operation ever, but I got through it ok
    wished I had taken some pics
    let's ride safe & be careful out there,
    Mike in Nawlins'
    2014 Black SE6 Limited "Charlotte"
    New Orleans Ride Captain
    Patriot Guard Riders
    Nov 2013
    Oro Valley Arizona
    Quote Originally Posted by cptjam View Post
    Some Guys just have bigger "cahones' Joe.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Dec 2014
    Lee's Summit, MO
    I used a motorcycle/atv lift under each front tire.
    Nov 2013
    Oro Valley Arizona
    I got Joe and Ann to do mine. Worked great. Ann held up the Spyder while Joe did the work. Damn that Ann is one Strong women! These two are professionals. Don't try this at home.
    Jack
    2015 BMW R1200R LC
    Mar 2016
    Akron,Ohio
    Default sway bar install
    Thanks to all who responded. I installed Rons sway bar today. I use the car ramp method. Jacked it up higher just for a minute to swap the old bar for the new one. Rons instructions were fantastic and easy to follow. Really an easy install.
    Russ
    Active Member LJspydee's Avatar
    Nov 2012
    Casa GrandeAZ/formally WaterlooIA
    Default Swaybar install
    Just yesterday I helped a friend install a swaybar, bumpskid and highway pegs on a 2014 RTLtd. Run the Spyder up a pair of ramps on the tailgate of my pickup. Plenty of room.
    2013 Silverado 2500HD Duramax
    2017 Honda Pilot
    2018 Maverick Trail 1000 DPS
    2015 RTS SE6 Intense Red Pearl
    2014 35' Keystone Fuzion Impact Toyhauler
    Ultimate Seats passenger backrest, Adjustable wind deflectors, Minitrailer USA trailer, Can Am driver backrest, Corbin passenger armrests, after market hitch, DIY bump skid, LED turn indicaters, cup holders, frunk decal stripes, DIY GPS mount, DIY Gopro dash mount, aux 12v & USB outlets, DIY belt rock shield, BajaRon swaybar, frunk 12v outlet
