Mine mount has the connector on it, I am wondering if there is a place on the wiring harness to plug that connector into?
On the F3, the GPS power is on right side, under the small rear panel. You will have to remove the seats to be able to remove the panel. Make sure you check the polarity of the connector before you just plug in your GPS.
