Results 1 to 2 of 2
Hybrid View
    May 2011
    Queen Creek, Arizona
    Default Roadster Electronic Command Center
    2010 RT 25000 Miles The screen does not always come up. Some times for many minutes or many miles. Shutting down and restarting does not help.
    Default As I see it...
    You have a power source problem or a faulty panel. I would pull the panel check the plugs and pins then all the battery connections and batterey condition. Now if any changes were made such as addition lighting HID, LED etc I would double check those connections and systems... good luck and hope it is a simple solution but either way let us know what you find....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
