2015 rt limited vib or shudder question.
Hi. This is my first post. I test rode a 2015 rt limited demo bike. Had a couple hundred miles on it. Loved the ride. The two things I noticed was It has a bit of body tilt in corners which the BajaRon sway bar should fix. The most concerning thing was around 75-80 MPH it seem to vibrate or shudder quite a bit. Like the drive belt was flapping. Is this normal. I ride Interstate a lot and would be at this speed. Any help would be great.
Take a look at this thread starting at post #7 (belt harmonics). I've got similar, around 3800-4000 RPM and 75-80mph, comes and goes. I'm going to have dealer check belt soon.
NEW/CURRENT (Wife's Bike, I ride Goldwing/Africa Twin)
2023 RT Limited Petrol Blue Metallic
Working on the upgrades... so far... Show Chrome Isolator Fuse Block, Tackform Adventure Wireless charger phone mount
OLD/TRADED
2015 RT Limited Intense Red Pearl
Farkles: Ultimate Tallboy seat, FOBO, JT Dash Mount, Lamonster Spyder Cuff, Kradellock, TricLED lighting - fenders, A-Arms, saddlebags, run/brake, Custom Dynamics high brake light, brake modulator, Drink2Go passenger, MUTH turn signal mirrors, Bajaron sway bar, Kuryakyn ISO grips, SpyderTV front grilles & rear trunk organizer, homemade trunk light
Pending: Elka shocks, Yokohama S Drive rear tire, EVO 595 front tires, Centramatic balancers, Neutrino black box
Belt harmonics is a known issue on F3's. Last I heard, BRP was looking for a fix. Have not noticed any information saying that the mission has been completed.
Belt harmonics also show up on other versions, but not on every .
I have not experienced the effect on any of the that I owned or ridden. Most people just find a slightly different speed and continue on.
I do know if I had a unit with harmonics, that I would not be a happy camper though.
F3 Vibration
I feel the vibration also between 67-72 MPH. Waiting to see if BRP is going to fix the issue. Sponsors have fixes but a little to much for my wallet.
God bless those who serve/served our country!
I just finished installing the Baja Ron bar and the shock adjusters on my 2014 RTL. It made a world of difference. I highly recommend both. My RT also has a belt shudder that comes and goes. I may spring for one of the roller belt tensioners at some point in the future. I'm going to let it break in a little more before I do that. Next on my list is a laser alignment then I'm going to get some seat time on it.
I got my demo RT in October of 2015. Had to have them balance the tires as it had a vibration at highway speeds. Noticed it during the test drive, so I got it done before I took it home.
Try this..
The sway bar and a good alignment will fix that for you. On the vibration you can check to see if it clears up before and after that speed then deal with it. You can have the belt tension checked (F3's have a different belt) and you can also add a belt tensioner...
2012 RS sm5
I had the vibration on my '14 RTL. After a laser alignment and belt re-adjustment, it pretty much went away.
I guess I don't understand why the belt vibration bugs people so much. For me it accomplishes a few things; it lets me know how fast I'm going and the vibration feels good on my feet when I'm on a long ride.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
I have a 2015 RT Limited that had a bad vibration at about 70 mph. Having read here that some people found their wheels weren't properly balanced when new, I figured I would need to have mine checked. However, a quick check with a torque wrench proved that none of the front 6 lugs were properly torqued. One was almost finger loose. After properly torquing the nuts to 77 ft/lb. The ride is vastly improved. Still considering a road-force balance though.
What fix do sponsors have.
vibration
Smoothspyder, see under vendors here, has a belt tensioner that will fix the issue for about $250. I think the vibration is pretty common, my 2015 RT S has it. Maybe one day I will spend the $$ to fix it but for now I have other farkles I want more and I can live with the vibration.
VIBRATION
Or try this for ....FREE... loosen the belt, I know it may sound contrary to common wisdom......But I run my belt at about 185 lbs. using the Kritkit ( while tire on ground ) and I don't have any Vibration.......Mike
Works on mine....
So I read some post on the smooth spyder pully and watched a video. Seems like it will fix the shudder. Do most agree here. I need a trike and I do not see anything else like the Spyder out there. I do not like the ride of a traditional trike.
same issue
is this a warranty issue . Just asking
