Installing a switch
I am wanting to install a switch for led lighting in the spare spot with the other 4 switches.
My question is will that spare blank cover come off without removing the entire cluster.
Thanks all,
Butch
Yes you can pry it up and pop it out.
But to get the wiring and what not run it is helpful to remove the glove box. It's not that hard to do.
Bob
2011 RT-S SM5 - Black
Bob
Thanks my friend. I've had it off before I just don't want to do it.
Originally Posted by Jetfixer
It appears that all that was required was drilling a hole in the center section (apart from the wiring). Is that correct?
2020- RT Limited
Chalk White, Can-Am rear passenger armrests, Comfort Seat, Grip puppies, RAM Cup Holders, Providence RAM Mount
FOBO2 TPMS
Aluma MCTXL trailer
BRP hitch
Big Bike Parts wiring harness
Permanent Smile!!!
Not so much drilling a hole as enlarging the small round hole that's there to a rectangle the correct size to allow the new switch to "snap" in and stay. I used an xacto type knife and just took my time.
I have read that post. You are the one that got me to do this. I have that very same switch
Thanks my friend.
Butch
