Results 1 to 19 of 19
    Greensboro, NC
    Exclamation ECM Electronic Control Module gone bad at 18000 miles
    I have a 2012 RSS SE 5, I received a check transmission reading come on and ook it into the dealership and was told the ecm was bad. but the bike seem to be running great. I was told that two cylinders were not firing. Does this sound correct to anybody. I have 18000 miles on y Spyder. IS this normal?
    Very Active Member Big Arm's Avatar
    Jul 2008
    Sioux City, Iowa and Tucson, AZ
    If the two cylinders are not firing, how can it be running great.....Go to a different dealer......quick.
    Greensboro, NC
    That is my concern. It changed gears smoothly and there was no skipping or running rough, it cranked up normally and I didn't sense anything out of the ordinary. IF two cylinders weren't firing wouldn't run rough if it ran at all. I thought if the ECM went out it would shut down the bike.
    Default OMG
    Quote Originally Posted by Big Arm View Post
    ......I find this this ABSOLUTELY DISGUSTING .........This sounds like a classic case of " treat a woman as if she is a MORON " " She will believe ANYTHING ".......Big Arm is correct, if the plugs aren't firing the engine can't be running...PERIOD. I don't know if you bought from this STEALER but if you did they are treating you like DIRT......You need to pull up the codes and get back to us on this and someone here can probably help.......As long as you haven't gone into LIMP MODE it's not serious.........JMHO....Mike
    Very Active Member tobor9's Avatar
    May 2011
    Charleston,SC
    When my ECM failed on my '11RS i lost 1 cyl. it ran (like a 2cycle lawn mower!)i got home and had it trailered to dealer and had it replaced under BEST warrenty.
    2015 RT White,Tj's Dash mount,Rivco's Duel Flag Holder,SealsFloorBoards(Pups),Custom Dynamics fender lights(R/W)Bajaron's Swaybar & links,Lamonster's LED headlights,lidlox.Wiredux A-arm driving lights(upper&lower)FOBO TPMS system,Spyerpops lighted bumpskid,Foom handgrips.
    tobor9@me.com
    Very Active Member kep-up's Avatar
    Nov 2014
    Mountville, PA
    Quote Originally Posted by Spydey Girl View Post
    Spideygirl,
    your machine only HAS two cylinders. If two cylinders are not firing, it ain't running. Get away from that shop as fast as you can and never return for ANYTHING.
    Nov 2015
    Chardon, OH
    It hasn't happened to me personally, but a lot of folks here will swear by low oil level being the primary cause of most glitches with the SE5 transmission. Perhaps that would be the first thing to check and cross off the list.
    The second thing would be to search for a new dealer. That was one of the most dishonest or incompetent things I've ever heard a dealer say.
    Doug
    2012 Spyder RT LTD Lava Bronze, RT 622
    Original Owner
    Seal Pups, F4 Customs SWCV, Corbin, JT's Air Filter, Cat Bypass, Power Commander V, NBV, SpyderFlap, Rivco Dual Flag Holder, Lidlox, Baja Ron Sway Bar, links, plugs and wires, Adjustable Chrome Side Vents, Spyderpops Block Off Plate and Belt Guard, Bump Skid, Canisterectomy, Akrapovic, TricLed HL/FL, Spyder Cuff with X-Grip, S-Drive, Rock Armour, P238, Laser Alignment by Gray Ghost, Windshield Arm by Noboot, Vibration Dampener by Doc.
    Default Wow...!!
    Really right to the ECM..?? You need to get her back and find another dealer. That warning has many origins of which the ECM is the last and least common. As mentioned oil, gear positioning sensor, linkage, actuator etc are the places to start. If you let the computers reset and the warning goes away there may not be a problem. If it comes back then after oil I would look to the gear positioning sensor and the paddle shifter. I have seen this happen with several SE models where they were shifting to softly and by making the shifts more positive they had no more issues. Seems on a soft shift or hesitant tap the computer thinks you missed a gear or are between gears.
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    aka: akspyderman ARtraveler's Avatar
    NW Arkansas
    Another dealer that does not know much about the
    Time for a second opinion.
    Currently Owned: 2011 RT A&C SE5 (magnesium), 2014 RTS-SE6 (yellow), 2015 Vulcan 900 LTD
    Previously : 2008 GS-SM5 (silver), 2009 RS-SE5 (red), 2010 RT-S Premier Editon #474 (black) Pictures of 2008 and 2009 Spyders are in Alaska Albums 2009 and 2010.
    5 Spyders, 10 years, 145,375 miles
    Nov 2014
    Mountville, PA
    Quote Originally Posted by kep-up View Post
    Spideygirl,
    BTW, my 2011 RSS SE5 was sending me trans codes for quite some time. It wasn't shifting. Monkeyed with the oil level issue, didn't help. Ignored the message and simply shifted again until the message disappeared until it got so bad I could hardly get to shift into reverse or even change gears at all. Then I replaced the paddle switch assemblly. All better now.
    Houston
    ECM failures are actually VERY rare yet its the item many unknowing dealers or mechanics jump to first. Likely because they know the least about it.
    There is a great deal of diagnostic work that needs to be done before one can determine a ECM is bad. Your dealer is lying to you in order to attempt to STEAL from you. Its that simple. You need to get your bike and leave.
    In the unlikely event they have actually done the needed diagnostics and you just misunderstood what they were telling you, please get the diagnostic codes they pulled and the reason they think the ECM is bad. There are a number of experienced BRP techs here on the board that can help you.
    Blue Flame Spyder F3-S
    Active Member Koop's Avatar
    Feb 2016
    Where ever we can ride
    It may be a little harsh to say they're trying to steal. I spent a great part of my career as technical service representative for a major European auto company. I found many instances of technicians that didn't have proper training looking at a fault code (DTC) and then going for the easiest component to replace. It's a problem. So many so-called technicians have little education or understanding of the systems they're working on. In my 35 years of automotive experience I found the best shops invest in training, the worst employ back-yard parts changers.
    2009 Spyder Roadster
    Full-time in a 2003 Alpine Coach
    40' motorhome - we live where we're parked
    Oct 2013
    Brownsburg, IN
    Quote Originally Posted by Koop View Post
    If they told her two cylinders were not firing when the engine only HAS two cylinders, they were trying to steal from her. That's as flagrant as telling someone they need to change the air in their tires.
    Apr 2018
    La Cresenta California
    hey there my ECM went out after i changed the spark plugs and wires, it turns out when you do that you have to disconnect the negative battery cable then work on the bike. Changing out an ECM is very easy though! remove the left front panel and get under the dash and you will see it it plugs in and out very simple. By the way my bike was able to start and run on ONE cylinder only. The dealer wanted $1700 dollars to change it out, i found the ECM on Amazon and bought for $500 and changed it myself, i have never returned to that dealer by the way, i do most of my own work now.
    Quote Originally Posted by soloflyr View Post
    I have changed a number of spark plug wire sets and I've had hundreds of customers do the same. I'm not saying don't remove the negative cable from your battery. It never hurts. But you're the first person I've heard say a spark plug and wire change was the reason for an ECM failure. The ignition system (at least the wires and plugs) have no affect on the battery or ECM when the system is shut off. I suspect it may have been something else which occurred during the spark plug and wire change that created this problem.
    Oct 2014
    Fort Mill, SC
    2011 RTS
    1998 Honda Valkyrie
    US Navy Veteran
    Member: American Legion
    Active Member Don'tPanic's Avatar
    Oct 2017
    Pennsylvania
    That's actually funny in a not-funny way. You should ask the dealer which two cylinders are not firing, and have them physically show you on a twin engine, that only has two cylinders
    ECM almost never fails unless it's burned out, but for that you need to either reverse the polarity (connect positive cable to the negative battery terminal and negative cable to positive terminal) or be next to an atomic bomb explosion - it will fry the electronics with an EMP pulse.
    Out of all the possible simple issues your dealer chose the two impossible ones
    Like everyone says here - don't ever go to that dealer again.
    Quote Originally Posted by Don'tPanic View Post
    I know of one that did fail ….. some of the Prongs inside the plug connector, corroded, which rendered the ECM as - not functioning ….. Mike
    Apr 2018
    Hey Ron as a matter of fact i purchased the plugs and wires from you, that is why i was perplexed. i ran on the number one cylinder till i took it into the dealer, when they told me $1700 dollars i was soo pissed i took my bike and left. I thought to myself with all the diagnostic equipment they have this is the best that they can come up with? By the way my bike is now throwing a VSS fault code and limp home mode when i take it out. I have not changed anything or done anything to it as of late of than change the brakes front and back. do you have idea what could cause this? Thanks in advance
