Results 1 to 7 of 7
    Mar 2013
    Canada
    Default FENDER LED HOOKUP ?
    Good afternoon All.
    I have just purchased a set of LED strips to be mounted on the fender indentation.
    They are cheap, but I figured I would try them for the hell of it.
    Question : These strips come with 3 wires.
    2 of the 3 wires are to be connected in such a way, that the LED strip is to be used as day time driving ( WHITE LED )
    the 3 wire is to be connected in such a way, to be used as a flasher ( ORANGE LED )
    How should I connect these in order to achieve the driving light and flasher light when needed.
    See pic below.
    Thanks
    Dom
    Default 3 WIRE LED
    ....Welcome to the world of DIY......For a running light you only need to connect that wire to the same wire as the tip or side marker ( if you have one ) because they are on ALL the time.......For it to FLASH -- like " with the turn signal " ....you will need to bring a wire down from the turn signal harness to your LED to power that wire.....UNLESS someone has an easier method of doing this .........I'm listening also......Mike
    Registered Users sinner45's Avatar
    Aug 2015
    fargo n d 58103
    Third wire to ground???
    Sent from my XT1080 using Tapatalk
    Registered Users lou49's Avatar
    Sep 2013
    lake mary fl.
    I don't know where those lights are made, but be careful with those, specially the ones made in china! You buy them cheap, because they're cheaply made! I got a pair of l e d head lights for my car and they came with reverse polarity! Hope everything goes flawless with your farkle! Post pictures with finish product!
    Very Active Member pitzerwm's Avatar
    Nov 2014
    TriCities, WA
    I'd check them on a work bench before going to the bother of installing to make sure they work. And they look like you want them to look. I have a few sitting around that didn't pass the test of "looks"
    One of the hardest decisions you'll ever face in life is choosing whether to walk away or try harder.
    Bossier LoUiSiAna
    Quote Originally Posted by pitzerwm View Post
    Glad you found lights good.From the little i see in pic, i dont think they will be bright enough for safety, they look more indoor type. You also might get hyper flash if you hook to your blinkers. Good luck
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Jan 2015
    southern WI
    Yup, put em on the bench first. I don't think they'll put out enough light to even bother go through the troubles, and potential issues. I agree, they look "indoor" worthy but not meant for a vibrating, weather exposed machine. Good luck. I'd also like to see a daytime picture if you go through with the install. Nighttime pics are worthless...all lights look bright enough at night. It's the daytime affect that other drivers see, that I would wanna see. If you can't tell they're even on during the day, to me it's not worth the trouble and expense.
    2016 RTS , Pearl White
