Results 1 to 24 of 24
    Mar 2016
    Cheyenne, Wyoming
    Default Curious-rear wheel
    I am just curious as to what everyone is being charged to replace the rear tire on a Spyder. Not the price of the tire but the cost of pulling the rear wheel, changing tires and reinstalling it.
    Fifty Bucks at Netzley Tire...
    And only Eight-Two for the Kumho tire!
    Feb 2012
    Spring City,Utah
    I pulled my own wheel,so mount and balance and old tire disposal was $25.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Default REAR TIRE CHANGE
    EVERYONE .....that's going to be a VERY long list.......................Seriously, what Bob D. is paying is like a GIFT from Netzley tire , and they are not BRP dealers.........At BRP dealers it is probably going to be shop rate hours, if you purchase tire from them a separate factor ( usually in your favor ) ......PS, if you plan to bring YOUR tire if it's not a KENDA better ask in advance , because many dealers will not mount any tires other than Kenda's...........Mike
    Good point! Check with your dealer first!
    (We are pretty lucky to have the Netzleys nearby! )
    May 2013
    Stanton, ca
    Noooooooo.......
    2011 RT-S SM5 - Black
    I believe the last rear tire I bought was $185 and the install was another $150 or so. Sold and installed by the dealer--who will not use any other than OEM tires.
    Mar 2016
    Cheyenne, Wyoming
    Default My Spyder dealer
    Quote Originally Posted by Michael82009 View Post
    My Spyder dealer wants $180 for the rear and $100 each for the fronts😡 That's outrageous I my book
    Default Don't know. ..!!
    But if you have a shop manual with the flat rates you can find the shop rate for the dealers and figure what their fee will be. Then you will see they add all kind of other stuff....
    ​2012 RS sm5
    Very Active Member M109Dreamer's Avatar
    Mar 2011
    Jackson, MS
    Do the maintenance manual list the shop maintenance/book listed? I have a pdf and i didnt see any listed.
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    2007 M109R LE - To many MODS to list. Its cheaper that way!!!
    Nov 2012
    Pueblo Colorado
    Default 36 mm socket and Big crescent or Crowfoot open end is a good investment..
    After the first rear tire change 4 years ago, I followed the excellent video posts from U-tube and enjoy the chance to work on it. Great feeling of accomplishment and 4 Kumhos and a Michelin later I'll probably keep changing the rear one myself. I figure I save about $200 on every change not including doubling the wear life by running a harder compound tire. At $2 gas that gets me a couple months riding or a couple of nights lodging on the road. And I get a chance to look over the brake pads and bearings while I'm at it. The last 4 rear tire changes have been enough to get comfortable with the process and torques.
    I may have the dealer put on the next two fronts though, as the OEM Kendas have worn well and the local dealer is reasonable. Everyones options and choice is different.
    2015 RT , OEM Black Gloss
    No, it comes with the green manual available online for around twenty bucks...
    ​2012 RS sm5
    Mar 2011
    Jackson, MS
    I have the green manual pdf. Is it a separate file or is it in the maintenance manual?
    Nov 2013
    Oro Valley Arizona
    If you buy your tire at Ride Now they install for free. I bought a Kenda with build date 34/15 (the new compound) for $179 total buy and install. Shop rate is $120 per hour. If I would of bought else where it would have cost an extra $120--$150 to install for a total of $299--$329. I prefer a M/C tire due to the light weight of the Spyder and softer compound for wet roads or panic stops.
    Build date 34/15 means it was built the 34th week of 2015. This is stamped on all tires due to Federal regulations. Ann and Joe Meyer said that the new Kenda tire compound started after 52/14 FYI.
    You know I hate to plug Ride Now but that is a very good deal. The new Kenda should get you anywhere from 15,000 to who knows. "Pampers" says she got 17,000. All depends on your driving habits, and the material of the roads where you drive. I got 9,000 on the old compound "Kenda". Maybe you should start calling me "Turtle".
    I always keep it under a Hundred.
    ​Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    In mine it is at the end as you scroll down the pages after the recalls bulletins etc...
    ​2012 RS sm5
    Active Member Derk's Avatar
    May 2011
    Pinehurst,NC
    Red face
    To answer your question, my dealer in Winston Salem charged me $97.00 to install the General Altimax I brought with me. I got 7500 miles on my Kenda. I'm anxious to see what mileage I get on the Altimax. I have a 2014 RT-SE6.
    Active Member Koop's Avatar
    Feb 2016
    Where ever we can ride
    Quote Originally Posted by jaherbst View Post
    Build date 34/15 means it was built the 34th week of 2015. This is stamped on all tires due to Federal regulations. Ann and Joe Meyer said that the new Kenda tire compound started after 54/14 FYI.
    ​Jack
    Hmmm...52 weeks in a year - how does 54/14 stack up?
    2009 Spyder Roadster
    Full-time in a 2003 Alpine Coach
    40' motorhome - we live where we're parked
    Registered Users satownsendsr's Avatar
    Jul 2014
    Mooresville, NC
    I brought my own tire (Aracnid) {sp} to the dealer after making sure that they would mount it. They charged me shop rate and if my memory serves me it was around $150 to remove the old tire, mount the new one, and align it along with setting the tension on the belt. My belt must of been out of specs on tension because after the new tire was mounted the vibration that I got at around 70 to 75 mph went away.
    Sent from my SM-P900 using Tapatalk
    Nov 2013
    Oro Valley Arizona
    Quote Originally Posted by Koop View Post
    OOPS!
    2015 BMW R1200R LC
    Invalid Emails
    Oct 2015
    Deland, FL
    Default Tire Date
    I read hat the magic date for compound change was 2514.
    Very Active Member Dan McNally's Avatar
    Jun 2013
    Here is BRPCare's post regarding the time change of the tire compound - 2013's and 2014's got the softer, stickier compound, until May, 2014.
    http://www.spyderlovers.com/forums/s...=tire+compound
    "Topper" is my Pearl White 2013 RT-LTD
    Professional Retiree - liked it so much when I retired from the USAF, that I started another career so I could do it again!
    Happy to be a member of the Maryland Spyder Web - find us at
    http://www.meetup.com/MarylandSpyderWeb/
    Very Active Member pitzerwm's Avatar
    Nov 2014
    TriCities, WA
    Ride Now here quoted me $300, just to mount my tire. A friend had a HF unit with an adapter for MC tires and you didn't need to remove the hub. HF apparently doesn't sell that adapter any more, but this place might be a solution. With what RN quoted me I could buy the unit and almost throw it away. http://www.nomartirechanger.com/Cycl...p/tc-ch100.htm
    Changing a few tires and its free.
    One of the hardest decisions you'll ever face in life is choosing whether to walk away or try harder.
