What do you mean by "tune up"? I suggest you check pg. 119-121 of the operator's guide. The 3,000 mile initial inspection is a lot of check ups, many of which are routine pre-ride operator actions. An oil and filter change is not a tune up. JMO.
otherwise be a vulgar brawl.
****************************** Cognac 2014 RT-S
There really isn't any such thing as a conventional 'Tune-Up' on the Spyder. No carbs to adjust, timing is fixed and controlled by the ECU, valves need virtually no maintenance if cared for properly (read lubrication). No points, no condenser, no rotor or cap.
You will need to change the ignition wires and spark plugs somewhere between 15k and 20k (average). The air cleaner will need changing eventually as will the fuel filter. It wouldn't hurt to run some fuel/injector treatment in the gas tank on occasion. But unless I've missed something (and I am sure someone will let me know if I have). That's about it.
It was used as a major selling point of the new 1330 engines...
Bob have you changed your hair style? You look so much different these days!
Jack
2015 BMW R1200R LC
2014 RTL SE6 Pearl White
2012 RT-622 trailer viper red
2011 Polaris Ranger green
2016 Can Am Maverick
