Results 1 to 23 of 23
Thread: Heat recall
    Mar 2015
    Savannah Ga
    Default Heat recall
    Dose anyone have an actual recall number for the panel replacement on the 2013 st for heat reduction? My dealer or BPR. Have no idea what I'm talking about
    Aug 2008
    MA & NH
    Default Bombardier
    NHTSA campaign ID # 15V095
    Feb. 2015
    Can Am 2013
    High engine compartment temperature
    This was the RT (corrected)
    Default What he said...
    I am surprised that the dealer is unaware... I would worry....
    ​2012 RS sm5
    Nov 2013
    Oro Valley Arizona
    The OP was asking about the ST not the RT. The recall was for the 2013 RT. There was a previous service bulletin I believe on panel replacement for the ST if memory serves me right and it was 2012 or 2011 for those who requested it. Others here would probably know more.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    Jun 2015
    Ritzville, Wa
    Default That's pretty odd
    Quote Originally Posted by Train View Post
    You have a dealer who is not familiar with the heat issue associated with the 2013 ST when the entire Sypder community knows about it? Maybe it's time to find a new dealer. Or maybe he's just blowing smoke up your pants leg. Even if you're not explaining the problem in sufficient detail, he should be able to piece the problem together. How did you find out that BRP doesn't know anything about it either? Hopefully, your dealer didn't tell you that.
    Greg Kamer
    USAF, 20 years, retired
    2018 Can Am Spyder RT-Limited
    Jul 2011
    Mitchell, Ontario, Canada
    Default No recall
    There is no recall for 13 ST to Replace the panels with 2014 ones. So no number. I got mine done under warranty. I personally had to call BRP folks in Wisconsin and plead my case. They issued a warranty claim number. I had to get it done before the first 2 year warranty period ended or it would not be done.
    2018 F3 LIMITED
    If you are experiencing an actual heat issue on your ST then you should do some further research. As mentioned above, the actual heat recall with air scoops was for 2013 RT's. Other cases have been handled on an individual basis, depending on need. Direct contact with BRP should be done--not here say from the dealer--if that is what happened in your case.
    Keep us posted.
    Mar 2013
    Oz
    Check out the thread on st airflow panels. Part numbers are shown.
    there is no Recall.
    it is a goodwill fix under warranty.
    by offering this goodwill fix, the st was not investigated by nhtsa (or whatever it is called)
    the panels are same as on 14st, a straight swap, no cutting or drilling.
    Suggest you look up the part number and give it to your dealer, advising him of your heat issues and/or gas boiling.
    Aug 2008
    MA & NH
    [QUOTE=billybovine;1103298]There is no recall for 13 ST to replace the panels with 2014 ones. So no number. I got mine done under warranty. They issued a warranty claim number.
    Sorry, above info is correct. The only other thing I found was the recall on the ST & RT which was associated with Tandem master cylinder manifold inlet (fire hazard) dated Sept. 2013.
    MelloYelloSpyder
    Guest
    Go to the BRP customer care and open up a complaint with them stating that you are getting a lot of heat from the engine. They will issue you a reference number. Then go to your dealer and have them open up a formal complaint and have them put the reference number in the body of the email they are sending BRP. I had mine in a couple of weeks and even with the bike out of warranty they replaced them as a show of good faith. BRP said that because the bike was out of warranty they would replace the panels at no charge but I would have to pay to have them installed. I elected to take the panels home and install them myself. Pretty straight forward on replacing the panels. Took me about an hour or so to do the job.
    Member RunSharon's Avatar
    Jan 2015
    West Virginia
    [QUOTE=MelloYelloSpyder;1103444]Go to the BRP customer care and open up a complaint with them stating that you are getting a lot of heat from the engine.
    This is how I got the panels on my 2013 ST Limited replaced. I even included pictures of how red my legs were after a ride. My first letter to BRP was ignored, but the pictures got their attention. Be persistent.
    Very Active Member ingramwc's Avatar
    Oct 2008
    Kingsport, TN
    "loisK" is correct. It is a "goodwill fix" by BRP through a dealer. A dealer needs to initiate the call to BRP. It is a straight swap of side panels, 2013 panels come off and 2014 panels are installed. No drilling, cutting, gluing, just swap the panels. The dealer I bought from was not aware of the problem either. It was a frustrating couple of months getting them to understand the problem, but they finally said the magic words to BRP and parts were shipped and installed and all is well now. I hope your process is quicker and less frustrating than mine.
    If the dealer starts talking about a recall and cutting holes for vents, that is a recall for RT models only, not for ST models.
    Good luck!!!!!!!!!!!!!!!!!
    Current ride: 2013 Circuit Yellow ST-S SE5
    Active Member JCWeatherman's Avatar
    Aug 2015
    Lancaster County, Pennsylvania, USA
    Default 2013 ST Limited Heat Issue
    Last year I bought a used 2013 ST Limited. After a couple weeks of riding in August heat, I could no longer take the pain. I found some posts in SpyderLovers that talked about dealers voluntarily replacing 2013 panels with 2014 panels. I went to my dealer and asked the salesman who sold me the bike about it. He pulled up a service bulletin and read it to me. It instructed dealers to replace the 2013 panels upon request. It went so far as to say that if the correct color was not available, the dealer should order replacements, take them to an auto body shop, and have them painted to match.
    The next week I had new, matching panels. That's the way it should be for everybody who wants it.
    All the best,
    John
    2022 RT Limited
    • Garmin XT (I would be lost without it)
      Driving Lights (Very bright to improve my sight)
      Floorboard Lights and Turn Signals (I like to be seen)
      Passenger Armrests (So my wife doesn't fall off)
      Trailer Hitch (So we can bring more stuff with us)
      Chrome Wheels (Because the beautiful stock wheels just weren't good enough)
      Front Fender Sequential Reflector Lights (I was wondering what to do with my paycheck)
    Active Member nhoj's Avatar
    Apr 2012
    Aurora Ontario, Canada
    Default Part Numbers for retrofitting 2014 panels on 2013 ST
    Marilyn 2023 RTL Red
    John 2023 RTL Black
    previous:
    2015 RTS SE6 Red
    2015 F3S SE6 Silver
    2011 RT SM5 Silver
    2013 STS SM5 Silver
    "common sense will prevail....but we see no sign of that"
    Active Member clinard's Avatar
    Oct 2014
    Southeast Mo
    Default May be more than the recall panels
    I also purchased a used 2013 ST that had a heat problem. After having the recall panels done it was better but still not exactly right. I found that there was a heat deflector on the right side that had some how disappeared or never installed. I purchased and installed the necessary parts from Cheap Cycle Parts and life is good. If you look through the large opening on the right side panel and can see the engine then you are missing the deflector. If its has the deflector in place then the engine won't be visible. With it missing all the heat just blows straight back and heats up your leg.
    Active Member Commander's Avatar
    Jun 2014
    Southern New Jersey
    I believe if you went on the Can Am website you can put your VIN number in and it will give you the information including the recall number as well as the work that has to be done. When I had my recall work done on my 2013 RTL i printed out everything and it even included the template for cutting the tupperware for the scoops.
    Oct 2008
    Kingsport, TN
    There is no recall number for ST models for the heat problem. RT models are the only ones to have an official recall number. The ST FIX IS A Goodwill Fix by BRP, not a recall.
    I know you are trying to help but if a ST owner approaches a dealer saying it is a recall it will just cause frustration on the owners part as he/she will end up chasing a rainbow.
    Active Member WEB-WVR's Avatar
    Sep 2009
    Albany, Oregon
    Cool
    Keep us posted.
    I agree. The recall was RT's.
    I am not aware of a heat issue / recall for the ST's.
    Craig From Albany Oregon
    Oct 2008
    Kingsport, TN
    The heat issue only affected the 2013 ST models, the solution is to install the vented side panels that were standard on 2014 ST models. It was not made a recall by BRP.
    However they, BRP, will replace the panels at no charge to the owner and allow 45 minutes labor to the dealer. A dealer needs to initiate the process by calling BRP and ordering the correct parts.
    ...in the pink (Girls On Spyders) flamingobabe's Avatar
    May 2010
    Friendswood, Texas
    The 2014 panels are a Goodwill fix from BRP.....no recall....but check to see if the master cylinder recall has been done.....go to dealer and run vin# to see what has been done to your ST....another great help to go along with the 2014 panels is a cat bi-pass....check with Pitfall Powersports 417-863-1418.....it will help a bunch with heat
    #IamARyder #RideASpyder #CanAmSpyder
    Feb 2016
    Mill Creek ,WA
    My wife just purchased a brand new 2013 ST from Lifestyles in Mount Vernon, WA, site sponsor... Heckuva deal btw! They handled the heat panel issue in minutes setting up the claim, no questions asked, and she only had 51 miles on the Spyder. Our girlfriend had 3000 on her ST Limited, had never heard of the issue but complained it was very hot, they took care of her also. New panels in a week.
    Apr 2015
    Puyallup, WA
    Quote Originally Posted by DuaneR View Post
    Lifestyles is great! We put money down last year on a new 2013 ST limiited (9 miles on it)...and when when we went back to pick it up they had replaced the panels without us even asking. I had found out about the panels after we initially saw it and was going to inquire when we went back. Again...great dealer!
    2013 Spyder ST Limited...Akrapovic Sport Silencer, Fog Lights, Backrest, Spyderpops BumpSkid, 2014 cooling panels, BajaRon swaybar, Fox shocks, RS-S mag wheels...
    2014 Spyder RT-S, Spyderpops BumpSkid, BajaRon Swaybar, TricLED lighting, Magic Mirrors, Akrapovic Sport Silencer...
    Oct 2008
    Kingsport, TN
    Lifestyles sounds like a great dealership, may they remain so! Excellent service is becoming a rare find these days!!!!
