TricLED 3rd/4th brake lights
I'm in the middle of installing the 3/4th brake lights from TricLED.
Question:
Each LED strip attaches permanently to one of two different body panels.
The two LED strips are wired together and do not appear to be simple plug-and-play separable.
Specifically, the two black ground wires are crimped together into a single plug; the red wires are connected in a small gray junction block with orange press-down levers (are these wires able to be disconnected by prying up on the orange levers, or is that a one-time permanent union?)
This arrangement makes the two main rear body panels Siamesed by this wiring so if you remove the one upper (painted) panel that fits right below the trunk lid, you must also remove the lower black fender panel and keep these two bulky pieces together.
Do folk cut the red and black wires and connect/disconnect with reusable Posi-tap connectors?
What am I missing here? I feel like I'm suffering a cranio-rectal inversion.
Pete Tamblyn
Cleveland, GA
2020 F3 Limited (black)
Time Out XL1800 cargo trailer
2019 Royal Enfield 650 Interceptor
2018 Kawasaki Versys-X 300
2013 ST (sold)
2015 F3-S SOLD
2014 RT-Limited (cognac) SOLD
When I installed mine I cut wires and used positaps, make its much easier.
2012 RTS SE5, GT stripes, belt guard, hmt brake light, lower vent heat deflector, driver foot boards, Corbin seat, RH vent covers
posi-taps to the rescue
Strange the directions make absolutely no mention of this dilemma................
.......or does no one else find having the panels hooked together by the wiring harness an issue?
Pete Tamblyn
Cleveland, GA
2013 ST (sold)
2015 F3-S SOLD
I use waterproof jst connectors...cheap from china
http://www.ebay.com/itm/30-Pairs-Wat...qIAAOSwSdZWcSA-
or posi's or crimp on spade or bullet connectors
eezee peezee
let's ride safe & be careful out there,
Mike in Nawlins'
2014 Black SE6 Limited "Charlotte"
New Orleans Ride Captain
Patriot Guard Riders
Installation video?
Several folks have mentioned that the Tricled website has installation videos. While I know my memory is going, guess my eyesight is too. I've looked and not found any. Help?
2016 RTS SE6
'64 Honda CA95 "Dream"
Hi, our website don't have installation video. However, we uploaded some installation video into YouTube. I hope this helps.
link to TricLED 3/4 brake LED installation
[QUOTE=Cindy-TricLED;1103406]Hi, our website don't have installation video.
Cindy:
A preliminary search on YouTube didn't turn up an installation instruction video.
Could you provide a link please?
Thanks,
Pete Tamblyn
Cleveland, GA
2013 ST (sold)
2015 F3-S SOLD
Listing would be helpful
It would be VERY helpful to have a list of links to these uploaded videos. Your company has an excellent reputation for helping folks installing/maintaining your products....this list would only serve to enhance that reputation. Just sayin.
2016 RTS SE6
Pete Tamblyn
Cleveland, GA
2013 ST (sold)
2015 F3-S SOLD
Thank you for your suggestion Old Prof.
We are looking into this and to improve the process.
I hope to be taking the parts off again this weekend now that my mini disconnects have arrived from Amazon. I have to say I was more than surprised when I discovered that the two panels cannot be separated for maintenance purposes.
While it is an easy fix, the correct connectors are worth about .25 cents each and will take no time to install when the harness is being wired up.
