Page 2 of 2 FirstFirst 12
Results 26 to 35 of 35
  1. #26
    May 2016
    Winnipeg, Manitoba, CANADA
    Default Spyder Trailer
    Quote Originally Posted by RunSharon View Post
    I have a 2013 ST Limited that I want to tow from FL to WV. I'm looking for a trailer, not too costly but one that I know my Spyder will travel safely on through the mountains of NC, Va and WV. I know nothing about hauling my Spyder so your help and advise is greatly appreciated. I have a Jeep Cherokee that will be pulling the trailer. Thank you, thank you, thank you!
    Stinger ... https://ca.stingertrailer.com/produc...pyder-trailer/
    $2499 CAD ... that means only $1845 USD
  2. #27
    Default this trailer
    Quote Originally Posted by MurrayBrown View Post
    This trailer doesn't appear to have ANY suspension ...... I don't think I'd want my Spyder to take that kind of ride .... jmho .... Mike
  3. #28
    Aug 2017
    New Jersey
    Agree about the suspension. Also in general looks kinda flimsy to me for the money. (Price now shows as $2499 USD)
    If I were to look for a trailer, it'd be a Kendon. I have had one for a while and it's fantastic. Mine's a 'regular' single bike model, not big enough for a Spyder.
  4. #29
    Apr 2016
    Greenfieldl
    How much room between the wheel wells. I am looking a 2018 RT and it looks close
  5. #30
    Sep 2018
    Caledonia,Ontario,Canada
    I use one for my sport bike and sometime a maxi scooter. You use bikes suspension, no harm to bike if you do not crank it down hard. Has a great chock for bikes.
    Well made units from Canada.
  6. #31
    Nov 2018
    Claremore, Ok.
    My windshield sticks up pretty high. Wouldn't it have a tendency to blow off towing it backwards? Mine is a RT vs. your RS. Is your RS windshield lower?
  7. #32
    Bossier LoUiSiAna
    Quote Originally Posted by Bobleach45 View Post
    The opening on the back end of the trailers at Uhaul are not wide enough to get a Spyder through. I looked into those last year. A friend has an Aluma Trailer that works great and I we take him and his wife out for dinner when we use it.
    Take a look at a new post today about an Aluma trailer in Northeast Alabama that just went on for sale in this forum.
    Not all U hauls have the right trailer 6X8
    IMG_6447.JPGIMG_6448.JPG FYI not my in pic. But there was at least 1 trailer floating around U haul somewhere. If you have nowhere to store said trailer when not in use U Haul is handy, condition of the trailer may/may not be, it is a rental. If you have space & budget go ahead & spring for an enclosed trailer say 7X12 they well suited for many things.
  8. #33
    Nov 2018
    Denver, Colorado
    How do you get it in and out?
  9. #34
    Hubert, NC
    New to Spyders just purchased a 2014 ST Limited and new to the Forum. I have two tow vehicles. A Tacoma that will pull up to 6,000 lbs and a Passat TDI that will pull up to 2,000. So i chose to go to an all aluminum keeping the trailer weight around 500 lbs. Aluma makes dedicated motorcycle trailers MC-1, MC-210 and the TK-1. The 210 and TK=1 will carry a Spyder. But these trailers are for the most part a single purpose trailer. Aluma makes several utility trailers that will fit the Spyder width and length. Unless you are also hauling a motorcycle trailer the 6310 with a 65" x 120" bed will work and the nose does not need to extend over the front allowing you to use the front solid 24" faring to protect the front of the mc. I also purchased the 24" side picket fences and opted for the bi=fold rear tail gate. Its slightly longer than the single ramp but has less wind resistance in the folded position. I have the option of taking off the side (and front) fences when I am carrying the Spyder. I really like the MC ramp that slides in below the deck but for hauling "stuff" you sometimes need a rear gate.
    Aluma 6310 HBT w 24%22st.jpg.
    I ended up buying the 6310 HBT w 24"st with a spare wheel and 4 flush D-Ring tie downs for slightly less than the TK-1 and much less than MC210. I opted for the "H" which means it has a 3500lb axel and 14" tires. I can haul up to 3,000 lb of dirt, mulch, rocks etc. but then I have to use the Taco. For hauling sand or mulch I place a big tarp in the bed, fill the bed and wrap the load like a big burrito. So now my motorcycle tailer is a dual purpose trailer. BTW way I use to have Kendon dual MC trailers. Two issues. I hauled one of my BMW's up to Alaska. By the time I got to Anchorage there wasn't any paint (power coating) on the leading edge of any of the steel. Second by the time I turned 70 I found it impossible to lift up the trailer to store vertical by myself.
    I find I use the utility trailer often around the house and maybe only once a year to transport a motorcycle. I now live near the coast in North Caroline so the aluminum trailer seems to hold up to the weather much better than my Kendon ever did in Alaska.
  10. #35
    Aug 2018
    Thousand Islands
    Depending what you are pulling it with suggestion of renting a uhaul trailer may not work, the only uhaul trailer in my area that could fit my spyder was 6 x 12 and they were damn heavy even without the spyder on it. And found out not all utility trailers can be rented one way.
Tags for this Thread
