Tire mounting?
The local can am dealer (also a Harley dealer) charges $100 per tire to mount a new tire. That is for the front. I was afraid to ask what they charge for the rear. Any ideas on how the get it done cheaper?
Just paid 120
Just paid 120 for a rear install. I feel your pain.
2014 RT-S Pearl White
WELLLLLLLLLLLLLLLLLLLLLLLLLLLLLL
Any place that does cars or pk-ups can mount and balance front tires......They can also do rear tires -- you must remove the sprocket and sometimes the hub........very very few can balance rear ( I don't and it works fine without - rear only )...........NO-ONE but a dealer or you are going to remove any wheels/tires from the Spyder....don't bother asking.......................Mike
Well, that's insane. I just pulled both of my front wheels yesterday and took them to my local tire shop with my own tires and got them mounted and balanced for 30 bucks total. There's nothing special about doing the fronts.
Doug
”Freedom is not a loophole”
Ozzie Ozzie Ozzie
Everyone above has you covered. Just to add a few personal experiences...
-A tire shop may get funny about the fronts if you tell them they are for a spyder. Tell them they are off a smart car.
-the rear can be balanced just like any other wheel if you completely strip it down and remove the bearings from the wheel. It fits on the balancer once the bearings are removed. Personally, I'm doing the bearings with every tire. They are cheap and easy.
