parking brake pulley not lined up
It's a 2012 SE5. I'm getting ready to change rear brake pads for the first time. While I'm at it, is there a way to correct this situation, where my parking brake pulley isn't lining up with the cable bracket?
Well....
I would make the appropriate bends to the brace to line it up. A cresent wrench tightened to the brace will let you bend it or if not handy that way have the dealer line it up. You don't want the cable hopping off at the wrong time.
2012 RS sm5
PARKING BRAKE
The pulley appears to be very close to the bracket compared to what mine looks like ( 2011 RSS, SE-5 )...I have 1/4" to 5/16th" clearance there............I would check the Pulley position........I also checked if it mattered whether the brake was on or off.....it didn't..................Mike
The pads were pretty near gone. When I pulled the pulley off to get to the mounting bolts for the brake assembly, I turned the spline shaft all the way CCW (several complete revs) and it looks like it might line up now when I put it all back together. That assumes that with new pads in place I won't have to spin it back in CW too far to get the parking brake adjusted correctly.
This will be my 3rd set of rear pads in 11k miles. I think they rub all the time. I have to adjust that P-brake every 600 miles or so. I asked the dealership about it and they say nothing is wrong.
I don't think that bracket is bent. It looks fine and has plates welded at 90 deg to each other so that it would be darn near impossible to bend without major damage.
Yep, now that it's all back together with the new pads the pulley lines up with the bracket.
POSTING REPLY'S
thank you thank you thank you thank you thank you thank you
I'd have to be taking a close look at your caliper,making certain that the slides were lubed properly and moved freely. Three sets of brakes in that few miles says that the caliper is not allowing the pads to withdraw from the rotor. Changed all the pads and I could have easily left them go another 10K; I currently have 17K on the original brakes. No i don't ride in a placid manner. I have never had to adjust the parking brake
All the great movements in the world began with a cup of coffee!
2018 F3-T
My mods: Can am Trailer hitch, USB and 12 volt power outlets, Gustason windshield, Bead rider seat cushion, battery harness for electric gear and battery tender, Time out trailer.
2013 STL SE5 BLACK CURRANT
SpyderPop's: LED bumpskid
minispyder dash toy
Lid lox
KradelLock
Pakitrack
FLO (Frunk Lid Organizer)
BRP fog lights, trailer hitch
SENA 20S EVO
BRAKE PADS
Originally Posted by Pappy John
I think y'all are correct, but I don't have a lot of experience with brake assemblies. The stealership replaced the pads once before and after that financial raping I decided to learn how to do it myself from now on. Many thanks to arntufun for the video. Half amazed myself when they actually worked after I was done.
While I had it in my hands I didn't see any springs which would apply pressure to open the caliper when not receiving hydraulic pressure. What is supposed to keep them open?
You are correct there are no springs; there are two pins encased in accordion rubber boots / sheaths which allows the caliper to move in when the brakes are applied and move back out and away from the disk...thus preventing continued contact, wear and heat build up. Your caliper is not moving freely as it was designed to do. Agree with the suggestion to have Pit Bull examine your brakes; call them now and schedule an appointment.
2018 F3-T
DISC BRAKES
