how to remove rear wheel
I have seen video on removing rear wheel by removing bolt that holds the shock, but can you remove it by turning out the adjusters a certain amount of turns then take of the belt like on a 2 wheel motorcycle?
richie spyder
2021 Sea To Sky, 2020 RTL
but our benefits don't?
The method of removing the shock bolt works real good. I used that method when I put on the Kuhmo and the belt went right back to where it was.
ok thanks but where do you do all the jacking up the bike from the frame or the swingarm?
richie spyder
Frame, as far back as you can get.
do not readjust the tentioners when you remove the axel the belt will be loose enough to remove the wheel
If you Measure the exact distance from each side of the axle to the end cap and loosen each adjuster the same amount of turns (Not too much) And turn the adjusters the same amount when done and remeasure the exact distances you can Do Away with laying on the ground taking of and putting back in the shock bolt which can be a pain if your Old like me. The manual has you do it this way.
Sea Doo GTI-SE 90 Jet Ski!!
I would read the manual as there is no need to remove the shock bolt.
Measure the adjusters or mark the ends.
Make sure the belt gap is correct to the edge of the pulley.
Make sure belt tension is correct..
There are plenty of threads already on this topic.
Good Luck
THE MEASURING METHOD
As far as the measuring method goes, be advised............as little as 1/4 turn on either adjustment bolt can move your belt +/- 1/8th inch ( from the flange )........1/4 turn is less than 1/96th inch of axel movement, maybe you can see that on a ruler ....I can't..............good luck............Mike
Jusr used the video'd technique on mine. Put on a new Kumho Solus. Everything worked well, but lossening the fasteners was the toughest part for me. Whatever thread locker they used was a bear! But the techique worked well, and the belt was aligned perfectly when reassembled. Recommend it highly.
I put my front end up on car ramps and then used regular car jack under the rearmost portion of the frame. Plenty of room to get at everything. And it is necessary to raise and lower a couple of times to get the load off the shock bolt and the axle.
Good luck.
John
Good Luck
The 'shock bolt' approach is an alternative to the 'official' approach discovered by some of the early Spyder Owners (Lamont did the original video). Having done both I found the 'shock bolt' method is both faster and easier - mainly because you don't have to muck about with the belt alignment/tension.
Removing the rear shock bolt is easy, and you wont mess with the belt alignment or the wheel alignment. IMHO
2016 Spyder F3 Limited Steel Black Metallic
Lamonster approved LED Headlights
Lamonsters LED Fog lights
BRP Driver & Passenger backrest
BRP Trailer Hitch
Shamrock Black & Polished
Signature light
Elka front shock's
Rolo Laser Alignment
Dual Power outlets
Garmin 590 GPS
Finless also recommends removing the sensor at the front of the swing bar, forget what it's called. Check out his video.
One of the hardest decisions you'll ever face in life is choosing whether to walk away or try harder.
PERSERVERANCE
Never thought of that but then the little tire shop here in Mt.Pleasant just mounted it no questions asked.
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
I did mine yesterday. Took it off but did not see any sensor wire in the front. Could be just an RT thing. took it to 2 car tire places and they would not do it. I called Richardson motorsports and they said they would do it for 37 dollars. I went there because I knew a Spyder dealer would not booger up my rim.
2017 F3 Limited
I got one of these wrenches off Ebay. I highly recommend it and it is small enough to add to your tool kit.
http://www.ebay.com/itm/191407295271...%3AMEBIDX%3AIT
2017 F3 Limited
only the rt has the sensor up front
richie spyder
