Results 1 to 11 of 11
Thread: Belt size
    Aug 2010
    marion va
    Default Belt size
    Does anybody know the size difference in a 2012 rt belt and a 2014 rt belt
    Sent from my SM-G900V using Tapatalk
    Default BELT SIZE
    The only different size belt that I'm aware of is the 2015 F-3 ....all versions of it are different from all other Spyders........Mike
    Jul 2011
    Mitchell, Ontario, Canada
    Yes the belts are different and I asked the question before. Did not get an answer.
    2018 F3 LIMITED
    Without being able to quote specifics : it's the same size, but has been built a bit stouter. (I think that this was done to handle the triple's increased torque output... )
    Jul 2011
    Do you really know or is it just a WAG? So just to be clear you are saying that BRP sells 2 different belts and both will fit the same?
    2018 F3 LIMITED
    All that I'm saying, is that they're the same overall diameter...
    They aren't interchangeable.
    Jul 2015
    Dorr, michigan
    Definitely 2 different part numbers.
    14 rt 705501304 Drive Belt
    12 rt
    705501576 Drive Belt
    2020 RT Limited , Petrol Blue
    Jul 2011
    Why aren't they interchangeable? The RT with the 1330 engine uses the same pulleys as the 998 engine RT's.
    2018 F3 LIMITED
    Dec 2010
    Telford, UK
    It would be smart PR to have the latest Spyder seeming to require a different (bigger/stronger/better) drive belt than the old model, wouldn't it?
    They have two different part numbers for the front sprockets...
    705502101 for 2012
    705502106 for 2016
    I didn't look up the rear sprocket numbers...
    All that I can say is: proceed with caution!
    Jul 2011
    705502101 for 2012
    705502106 for 2016
    Fronts both 28 tooth.
    Rears have various part numbers depending on the color. But the same color will be the same part number.
    2018 F3 LIMITED
