Results 1 to 4 of 4
    Acworth, GA
    Default 2013 floor board supports and boards installed on 2012 RT Limited
    Hi Everyone
    I wanted to post this because everyone I talked to except a mechanic in Mesa, AZ at a BRP Dealer told me that I could not install the 2013 Floor Board supports and floor boards on my 2012 RT Limited and I couldn’t find anything on this site about someone that had done the change. Well contrary to most belief’s it is possible and it’s as simple as taking the old supports and Pegs off and bolting the New ones on without any modification (except for the spacer in between the two bearings on the old brake pedal) which if I had known that the new brake pedal didn’t come with the bearings and spacer I would have ordered one from the start. Anyway I had to cut the old spacer down to about 5/8” from 1” to get it to work in the new pedal.
    I was able to pick up everything I needed for the install from a company on eBay and yes it isn’t cheap ($1345.00 shipped) but what a difference the new boards make on a long ride. Any way just wanted to post it in case someone else was thinking of changing their begs out for the Boards.
    SORRY I POSTED THIS IN THE WRONG SECTION
    Acworth, GA
    Default more pics
    as i had said in another post don't beat me up to much about the makeshift vice.
    Dec 2014
    Lee's Summit, MO
    Once you go to floorboards, you will never go back. Makes a great difference for riding comfort, especially on those all day rides and trips.
    May 2019
    stuart virginia
    I have a 2011 was wondering why the newer boards would not fit the older models thanks for the post this will be my next install I like the looks of the oem boards
