Results 1 to 19 of 19
Thread: Helmet speakers
    Hanover, PA
    Default Helmet speakers
    Hi all,
    I have the Scala Rider Cardio headset. My wife and I used the comm system for a little while but now we just yell if we want to talk. I use the system to plug into my iphone for music and directions. They are just not loud enough. I am looking for louder helmet speakers. Any suggestions wold be appreciated. Thanks.
    Active Member Crisis's Avatar
    Aug 2010
    New York
    Talk to Motorcycle Dave, he's a sponsor and a heck of a nice guy. He'll point you in right direction, call him.
    Active Member Colin's Avatar
    May 2011
    Karaka NZ
    Quote Originally Posted by rhansen309 View Post
    Hi all,
    Something to try first, maybe the speakers are too far away from your ears?? Yes I am serious. I found the same problem and fixed it.
    This is hard to explain, if your speakers are held in to your helmet with velcro. Get your self a couple of velcro spots that have the adhesive on the back, join them together with the adhesive sides touching, which you then attach to your speakers before placing them back into your helmet, it is only a matter of millimetres but does make a difference.
    It definitely worked for me.
    We now have His and Hers Spyders.
    Current Spyder, 2015 F3 Steel Black, Passenger Backrest, Blue Ridge Screen with Xcreen Extention, Akrapovic Muffler, Attitude Handlebars, Blades front rims, RT Swaybar,
    Her Spyder 2011 Magnesium RSS Sportrack and Backrest, Comfort Seat, Grip Puppies, 3.5 inch Riser Bars, Wespyd Signature Swaybar. Hindle Muffler, Godiva Screen, Hiway Pegs Can Am Panniers
    Previous Spyders
    2013 ST SM5
    2011 RSS
    2010 RS
    2015 F3 , Black with Blue Graphics
    Hanover, PA
    Quote Originally Posted by Colin View Post
    Thanks I read that while I was researching. I will try that before I spend any money. Thanks.
    Hanover, PA
    Quote Originally Posted by Crisis View Post
    Thanks. If I decide to buy any I will call him.
    Very Active Member Deer Slayer's Avatar
    Mar 2015
    Advance, NC
    Gotta ask, hearing test?
    If I can't fix it, I will fix it so no one can fix it. Sypder Loco!
    Oct 2015
    Orange City, FL
    We have the Scala gx9 set. I can hear mine with ear plugs. Has to be at highest or next to highest but I can still hear music or intercom.
    I would agree on the spacing.
    I cannot remember if the Scala kit or my helmet came with extra pads for spacing. It did say to make sure they were next to your ears though as each helmet and person's head is different.
    Mar 2015
    Advance, NC
    Quote Originally Posted by robertl View Post
    I will give you an Amen on spacing. I run the Sena 20 and the spacing was critical. You can get spacers from Sena. Good luck..
    Feb 2016
    Lake Wylie South Carolina
    Default question on 20's
    Quote Originally Posted by Deer Slayer View Post
    we just bought the 20s dual pack. We are having trouble with intercomm and music together. The music is jumping in and out all over the place. Everything works fine when only using one helmet. I was wondering if you might know anything about that?
    I thought the speakers on the Scala were not as good as the ones on our Sena. We use the headsets for communication only. There is no radio reception to speak of here.
    Oct 2013
    rome new york
    I use Torx speakers and their booster.
    Will blow yoyr ears off. And my hearing sucks from all the metal work i did through the years
    Think there are better units out there. Torx are very reasonable
    Mar 2015
    Brockport, NY
    Default Couple things to try
    Quote Originally Posted by Lili77 View Post
    I had a heck of a time getting our 20s units working properly. First step is to make sure everything is at the latest firmware, including the sm10 unit. What ended up fixing our setup was to make sure the setting that will turn down the music during intercom is set the same on both units. We actually just turned it off. We found that the less features that were on the better the sound and communication. We just have them streaming our Bluetooth and then we tap for intercom. Has been working quite well second half of last season.
    2014 RT-S Pearl White
    Oct 2011
    Kalamazoo, Mi
    1+ on the above, correct positioning is critical!!
    2018 F3-T
    2018 F3-T , Pearl White
    Hanover, PA
    Retired Air Force - jet engine mechanic on the A10. Greatest plane ever. Some hearing loss but not enough for hearing aids, at least not yet!!!
    Mar 2015
    forrest above Reno, Nv
    Thumbs up A-10
    The A-10 is a great plane!!!
    I thought I needed a hearing test also ( What!!) Teaching metal shop in high school is suprisingly LOUD (What!!)
    We have a Sena SMH -5 and it's plenty loud--- but the speakers must be placed corectly at the ear.
    Kaos
    2014 RTS , Circuit Yellow
    Aug 2013
    Northern California
    Default Bose
    I use a set of earbuds by Bose. They fit flush to my ears so they are still comfortable in the helmet. They provide a little reduction of road noise, and the sound is crystal clear with volume to spare. They would just plug in to the Scala where the speakers are plugged in.
    Mar 2015
    Advance, NC
    Sorry I am a single rider. Using the SM 10 to add xm sat radio tunes. Phone works great too. Rider to rider is great up to one mile LINE OF SIGHT!. Good luvk.
    Mar 2015
    Advance, NC
    What did you say? Titan I high pressure gas bleed off, 20 yr USAF Ret. The Sena close to my ears is great. Good luck.
    Hanover, PA
    My wife and I talked and I will try positioning the speakers first. Thanks all.
