Doesn't look right to me.
plus it's hanging from the ceiling. J/k!
It could just be the angle at which the photo was taken.
"Topper" is my Pearl White 2013 RT-LTD
Professional Retiree - liked it so much when I retired from the USAF, that I started another career so I could do it again!
Happy to be a member of the Maryland Spyder Web - find us at
http://www.meetup.com/MarylandSpyderWeb/
My dealer said it takes 4 hours to put together, how long has it been?
Ozzie Ozzie Ozzie
It also looks like the front tires are reversed.
Good luck,
Roger
2014 ST-L
Yikes...!!
But they actually don't turn parallel. The more you turn the more they are off. Not an expert on the reasoning for this but mine handles great this way...
2012 RS sm5
Definitely nothing to do with the angle of the photo or how wide the lens is........obviously a steering arm or something not adjusted yet.
I'm surprised something critical like that isn't adjusted during factory assembly
Just make sure it doesn't look that way when you get it.
2016 F3 Limited Special Series
The pix is old. About 2 weeks ago.
Ozzie Ozzie Ozzie
That could be used for an advertisement for a laser alignment.
Good luck,
Roger
DEFINITELY the front tires are on wrong. Reverse travel spin. DO NOT accept it this way and question your dealer.
2008 GS SE5 in 2008
Traded at 43,000 miles for a left over
2010 RT SM5 in 2011
Traded at 57,000 for a left over
2014 RTS SE6 in 2015, which has 35,000 miles
Oct 19th, 2017, totaled 2014 RT while killing a Javaline
Dec 12th, 2017 drove a 2017 F3L home. What an awesome machine!
Never had any breakdown stranded issues.
Maybe they are setting it up for Nascar??
2013 STL SE5 BLACK CURRANT
SpyderPop's: LED bumpskid
minispyder dash toy
Lid lox
KradelLock
Pakitrack
FLO (Frunk Lid Organizer)
BRP fog lights, trailer hitch
SENA 20S EVO
Ozzie Ozzie Ozzie
It's the steering geometry you're seeing combined with the angle at which the photo was taken.
You can read up about it here: https://en.wikipedia.org/wiki/Steering
The wheels/tires are mounted on the wrong sides and need to be swapped.
Just another crappy day in Paradise....Aloha!
i'd have the dealer swap sides on the front tires and run that bad boy right up to netzley tire in accord ny and get a laser alignment!! if they sent you a picture that way, they sure as hell don't know what they are doing!!
SpydermanCT
2010 RT-S SE5 Timeless Black PE # 794 ~ RT-622 Trailer ~ Can-Am Garmin 665 GPS ~ Elka Front Shocks ~ ESI Brightsides with Rips Kit ~ ESI RT Fender Tips Kit ~ Rear Brightsides ~ HMT Brake Light ~ Tricplate rear running / Brake LED's ~ ESI Mud Flap Lights ~ LED Day Runners ~ Right Side Inlet Covers ~ Street Magic Scuff Guards ~ IPS Key Cover ~ KewlMetal Kewlocks ~ Spyderpops Radiator Block Off Plate and Catalytic Converter Shield Set ~ Carbon Fiber Kit ~ Corbin Seat
The first NJ pothole will align just fine.
If I can't fix it, I will fix it so no one can fix it. Sypder Loco!
it appears that the tires are on the wrong side, they should be reversed. Look at the sidewalls and make sure the arrows are going in the right direction.
Cruzr Joe
SpyderLovers Sponsor
Don't Worry! These Guys are Professionals!
The definition of a 'Professional' simply means that they get paid for it. It has noting to do with their skill level!
Cruzr Joe
That is my question, what are you guys seeing that's telling you the tires are reversed. When I accuse them I want to sound like I know what I am talking about!
Sent from my SAMSUNG-SM-G928A using Tapatalk
I picked it up by looking at the "V" in the tread pattern.
Good luck,
Roger
2014 ST-L
