Won't go into reverse, won't automatically downshift
Bike has been sitting a few months. GO for a ride and reverse doesn't work, then, after a few miles, it won't automatically downshift. Any thoughts?
2015 RT with 3000 miles. Going in for service next weekend.
Thanks
2015 Spyder RT Special Edition
http://triketrek.com A website dedicated to the Spyder RT.
Farkle:
Utopia backrest
Garmin cheap ass GPS
Some canned sparkling water in trunk.
Intense Red Pearl/Steel Black Metallic
Travels so far:
Is it showing any error codes?
2015 Can Am Spyder RT Limited
A wild guess
I do not know much about the SE transmissions, but could your oil level be a little low? I am also posting this to keep your issue at the top of the new post. Just sayin'............
Three in the garage, and I think I can fit at least one more in.....and then we will have to build another garage.
The roads in NY are so bad that I am glad we bought a Ryker Rally
My shop manual says they need to plug in to the BUDS system and check the reverse switch and/or the hydraulic control module. Apparently nothing you can do yourself without the test equipment.
Nice Starship in the photo by your Spyder!
oil
If it was a twin, I'd say check oil first... not sure whether this is as much an issue with the triple. Keep us posted?
You could check the relay but PMK is probably right that it has to do with that service bulletin
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Originally Posted by PMK
Yes !
Dealer just replaced mine, no charge.
Thanks
Thanks. No codes. I'll bring it into the shop Saturday.
Too rainy to ride to test more right now. Seattle in Spring!
Farkle:
Utopia backrest
Travels so far:
