Page 3 of 3 FirstFirst 123
Results 51 to 55 of 55
  1. #51
    I am curious, since tires are often a big topic, where did you obtain ratings on the Altimax RT43? Are these the tire sidewall ratings or something I have not found on Tire Rack.
    I have found where Tire Rack tested a different version of the Altimax, but not this specific version.
    Actually She wasn't aware of what was a good tire or not !!!! …………. I suggested She get the Altimax to re-place the worn out Kenda …. Mike
  2. #52
    May 2009
    Connecticut
    Does it come in the stock size and can you use it in cold Temps because the Kumho I just put on is kinda slick even with 21 pounds? Not sticky like stock.
    Sea Doo GTI-SE 90 Jet Ski!!
  3. #53
    Quote Originally Posted by Sarge707 View Post
    If you are referring to the Altimax RT43 - the closest size is 215/60-15 , however this size will correct the speedo reading to almost exact..... Get the lower speed rated model it is actually a stickier tire …. should wear about the same tho …………. Mike
  4. #54
    May 2018
    Arizona
    I used tire rack.com for some research, amazon for some reviews but mainly here is where I looked for advice especially too see who recommended what tire the most. The Altimax was the name brand I’ve found to be the highest recommended, of course as one had said before a smile would ensue telling someone I have to check the tire pressure on my bikes Hankook, Falken etc would be cool as well. But as before I like the info here, the reviews given me insight and with that I purchased the tire and quite like it. I could tell how much smother it was when I rode home, and I could easily keep stable speeds compared to the Kenda, it is possible the Kenda was balding in the middle causing that but either way I’m really happy that I have the people and info here to help make that decision.
  5. #55
    Active Member starrider60's Avatar
    Aug 2017
    laurel, mississippi
    Had the General Altimex installed at 14,000. Have 2,000 miles on it with 20 psi. Much improved ride
