turn signal cancel
Just bought a 2013 Roadster ST. The right turn signal does not cancel. Any suggestions?
Just bought.... Dealer should fix, only question should be "when is convenient for you? "
2013 STL SE5 BLACK CURRANT
SpyderPop's: LED bumpskid
minispyder dash toy
Lid lox
KradelLock
Pakitrack
FLO (Frunk Lid Organizer)
BRP fog lights, trailer hitch
SENA 20S EVO
Before you go to dealer, try unsticking the switch. When I activate the switch it seems to stay stuck on and so I pop it back to center. Then it cancels with no problem. Not sure what cleaner would work. So haven't tried anything. Just got used to popping it back when I use it.
I have the same problem.The tech at me dealership took it apart and cleaned it out. That helped somewhat, but it still isn't great. I have to check after a left turn to make sure the signal is off.
Sent from my SM-N920V using Tapatalk
All the best,
John
2022 RT Limited
- Garmin XT (I would be lost without it)
Driving Lights (Very bright to improve my sight)
Floorboard Lights and Turn Signals (I like to be seen)
Passenger Armrests (So my wife doesn't fall off)
Trailer Hitch (So we can bring more stuff with us)
Chrome Wheels (Because the beautiful stock wheels just weren't good enough)
Front Fender Sequential Reflector Lights (I was wondering what to do with my paycheck)
Same here...
My son in law has the same problem on the left. (RSS 2013) My daughter don't.(RSS 2014) I don't. (ST 2013).
So, some do, some don't but certainly fixable by the dealer by replacing the defective part.
Richard
I stuck the hose of a can of wd-40 into the slot in the rubber seal on the turn signal switch. Shot a bunch of oil into it until it started leaking out the bottom. That was 3 years ago and have not had any trouble since.
2018 F3 LIMITED
So the RSS (2014) should have self cancelling turn signals? Mine does when making a real turn but not Lane change... Should it?
Will cancel after a normal turn but will not after a shallow turn or lane change. Also will cancel after 30 seconds of driving.
2018 F3 LIMITED
2014 sts
Mine will stick on right hand turns but if you center the switch life is good. Now when you turn left it will not cancel...at shop now I will let everone know what they find when and if I get it back.
Let's see....
There have been reports from time to time on this issue. In some cases a squirt of lube has solved it in others a bit of filing to keep the shaft from binding has done the trick. Now they all have self canceling turn signals but only on full turns and not on merges. Don't know which you are refering to , you can search the site for the solutions that were posted before...
2012 RS sm5
2012 Spyder RT-S SE5 Blue
Can Am: Floorboards, Tri-Axis handlebars, Comfort Seat, Front/Side/Rear cargo travel bags
Vendors: Air Hawk2 seat air cushion, Adjustable Side Window Deflectors, slip-on grip covers, RAM GPS mount & a short RAM socket arm... with a bicycle handlebar bell mounted to it - a carryover from my 2-wheeling days, it was great for getting your ridng buddy's attention when stopped at a traffic light
Originally Posted by billybovine
... Also will cancel after 30 seconds of driving.
That one's debatable. I've tested it several times and never had it cancel after 30 seconds. Other people swear that their's cancels after 20 - 30 seconds.
Trb-- (Roger)
2014 Cognac STL:Ultimate Seat, Nelson Rigg Tail Pack, Nelson Rigg RS/ST Half Cover, TL fender lights, Squared Away Laser Alignment, BajaRon sway bar and links, Akropovic Sport Silencer
2022 White Pearl F3T
Gone but not forgotten: 2019 F3S Special Series Liquid Titanium
Spyder States Visited
No need for debate. As long as the switch is not stuck. You maintain a speed of I think 3 MPH or greater. If you stop the count starts over and does not start again until you start moving again.
2018 F3 LIMITED
I had some issues with the earlier models, (2008, 2009, 2010). I just manually killed it as a matter of habit. The 2011 and 2014 work just fine.
My last 3 Goldwings had both cancel after turning and after 20-30 seconds but my ST only cancels after turning.
Susie - 2013 Spyder ST-Ltd
Flame Red '04 GL1800
'97 GL1500
'95 GL1500
'89 GL1500
'83 GL1100
Simple solution .................................. Don't turn, go straight.
Anonymous
Any updates?
minispyder dash toy
Lid lox
KradelLock
Pakitrack
SENA 20S EVO
I just picked mine up
Just got home from the shop and I had the same issues and they replaced steering angle sensor. 120 miles home and worked everytime!!
