Results 1 to 21 of 21
    Jun 2015
    Floyd County, VA
    Default Tank bag/Map holder
    Starting to plan a trip on my 2014 RTS SE6 - full length of the Natchez Trace Parkway. NPS has a wonderful map, which I would like to display on the top of my tank. Anyone found a good tank bag with map pocket or just a map holder?
    Tried a search and 'tank bag' got me lengthy discussions on fuel economy, and 'map holder' equally unrelated discussions on cup holders. So much for non-Google powered searches.
    Suggestions?
    Thanks, John
    Jun 2010
    Las Vegas
    My Aerostitch Darien pants have Velcro on the pants leg for attaching a map pouch. I just Googled Spyder Tank Bag and got a lot of replies. Kuryakyn and Nelson Rigg both make them.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Oct 2011
    Kalamazoo, Mi
    Nelson Riggs makes a nice one that's not too expensive.
    Last edited by IGETAROUND; 02-29-2016 at 08:39 AM. Reason: wrong ending, thanks Amme!!!
    2018 F3-T
    2018 F3-T , Pearl White
    Jun 2010
    Las Vegas
    Quote Originally Posted by IGETAROUND View Post
    Nelson Riddle makes a nice one that's not too expensive.
    I think you mean Nelson Rigg.
    2010 RT- 622
    Bossier LoUiSiAna
    They do have better selection of what will strap to a spyder. Also
    Corbin ImageUploadedByTapatalk1456720545.000535.jpg. Maybe.
    Sep 2014
    Northern California, US
    Here is a smaller tank "pouch" for the RT glovebox from Big Bike Parts - http://www.bigbikeparts.com/template...K&GroupGuid=78
    2014 RT Limited
    BajaRon sway bar, Tri-axis handlebars, shorty AM/FM antenna, Custom Dynamics HMT brake light with flash, Rivco cell phone mount, Utopia backrest w/pouch, Two Brothers exhaust. Lidlox helmet holder, FOBO TPMS, Drink2Go cup holder, WGT LED mirror light strips, Squared Away laser alignment, Kuhmo Solus 175/55 front tires.
    CanAm/BRP have a tank bag for the RS/ST's, & it's not too bad.
    With a little ingenuity it's fairly easy to mount their bag on the top of the RT glovebox/piewarmer (velcro pad on the glovebox lid with the hook part stuck on the bottom of the bag, & the two straps up front trhreaded thru the GPS brackets) & it works pretty well as a Map Holder with a handy sized bag underneath.
    My little dog actually spends a lot of time sitting in it, but I hafta leave the map holder bit folded forwards for that....
    Works OK for me & he loves it too - but when he's not in it, it still works as a Map Holder!
    Mar 2011
    gaines Michigan
    Won't these bags scratch the paint when dirt gets under them?
    Jun 2015
    Floyd County, VA
    Thanks for your help, folks. Got some work to do.... One of those should work.
    Thanks, John
    Jun 2015
    Floyd County, VA
    Quick search on Nelson Rigg site says that bag will not fit RT. Can Am bag is for RS only. Hopnel bag too small to display a map.
    Keep the ideas coming, folks.
    Thanks, John
    Yep, I said the CanAm bag wasn't specifically designed for the RT, but that it only took a little bit of velcro and about 1 minute looking at it to work out how to get it to fit securely on top of my RT's 'Glove-box'! And it fits well, sits nicely in place, holds all 2.5 kg of the dog without movement when I want it to but handles maps & other stuff the rest of the time, & it hasn't scratched the paint work yet (with about 18,000 miles in!)
    Very Active Member bmwlarry's Avatar
    Mar 2012
    Beaverton, Oregon
    I use a Cortech mini. It doesn't quite contour with the bike but has served its purpose for 5 years. I do place a bit of pad between bike and bottom of bag. I have also added a elastic strap with snaps to hold snug on bike. The snares are the type that screw in and the went below the lip and under the seat. The front strap goes around the steering shaft and stays there all the time. I also fabricated a larger map pocket and attach it with velcro squares. The bag is an older model so I do not know the availability.
    2015 an Am Spyder RT Limited
    2013 Yamaha WR250R - Sold
    2011 Can Am Spyder RT-S SE5 Limited - Sold
    2011 Aspen Sentry Trailer
    2003 BMW K1200LT - Sold
    2007 Unigo Trailer - Sold
    2001 BMW K1200LT - Sold
    2001 Honda 750 NightHawk - sold
    2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
    Mar 2012
    Beaverton, Oregon
    More pics
    Default I'm in....
    If we are voting...I have the Nelson Riggs and it is great. Always carry a paper map cause as nice as a gps, phone googlemaps may be they can never give you the big picture....
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Active Member kbwitt's Avatar
    Jun 2015
    AZ
    Default warrning pull out card
    I cut out blank sheet of paper the shape of the pull out warning card . Each day I have the directions taped on it works great
    Kenn
    Invalid Emails
    Feb 2013
    Castle Rock, Co.
    Nice set-up My GPS and map holder sits on the rear seat jtpollock
    Jun 2015
    Floyd County, VA
    Chupaca, is yours mounted on an RT? If not, could you speculate on mounting one on an RT?
    Thanks, John
    Jun 2015
    Floyd County, VA
    Quote Originally Posted by kbwitt View Post
    Kenn
    I use that technique regularly, but it will not work on the National Park Service map of the Trace.
    Thanks, John
    The Nelson Riggs tank bags are a universal mounting system. Velcro strap that goes around the steering shaft under the ignition and has clips that attach to the cover panel just under the front edge of the seat. My other travel bags are Kuryakyn but I never tried their tank bag...
    Sent from my SM-T560NU using Tapatalk
    ​2012 RS sm5
    Jun 2015
    Floyd County, VA
    Just to put some closure on this topic, after all your valuable feedback and a lot of thought,
    I think I will reuse an old TourMaster tank bag I've had for 20 years. It's magnetic mount,
    but with a foam waffle underneath and a couple of Velcro straps, I think it will be secure
    enough.
    Thanks again for your help.
    John
    Bossier LoUiSiAna
    Will quote myself spotted a cortech bag while back (took me while to find it in my pics)
