Switched from 2012 RSS SE5 to 2015 F3S SE6
Yesterday, I got the 2015 F3S SE6 due to the Spring Fever Event. My question is, when I had the RSS I knew to shift at 5200+ RPMs. I've read on here that somebody shifts at 3000 to 3500 RPMs. I looked at the manual several times and the only thing I could find was in the practice session it said to start and shift at 3000. I would like to know from veteran F3S ryders on what is a good range to shift at. My wife is going to ryde the 2012 RSS now. Thank you.
F-3 SHIFTING
The F-3 has the 1330 Ace engine, and has more HP and Torque......the power band is also lower.....So it can be shifted as low as 2500 RPM's without any strain to the drivetrain........Mike
Thank you all for the information. So in general, 2500 to 3500 is a good shift point? What would the highest that one person would go before shifting? It just seems that you would be shifting gears a lot through town. I just know the 998 is a high rev engine and switching to a low rev it freaks me out a little, I'm sorry for so many questions. Thank you.
The Automated System Cannot Shift Too Soon - trust it
Trust the way it's built - it won't let you shift before a certain amount of revs have built up, which varies from gear to gear.
First to second will take place at around 11mph and around or just over 2000 rpm, but 5th to 6th won't take place until you have about 2500rpm built up, at about 36 or 37mph.
You cannot lug (or damage this engine through running it too slowly,) because the gearbox will automatically shift down to a lower gear when necessary, even on the SE5.
The sooner you change the better your fuel economy.
I've found that the best shifting RPM's for me is 2500 for 1st to 2nd and then 3000 to 3500 for all gears above 2nd. 1st to 2nd is a little bit harsh above 2500, for me at least.
Just another crappy day in Paradise....Aloha!
SHIFT POINTS
There is a difference between WOULD GO...AND SHOULD GO..( for shifting )...You can always rev it to the red line on the tachometer.....But this is un-wise for a lot of reasons. You want to stay in the sweet spot of the Power Band if you are really Smoking it.......But for the best Gas mileage, you want to shift in the lower REV range as long as you aren't lugging the engine. This is something you will learn quickly if you are trying to learn your engine .....if you just go out and pleasure ride, it will take longer because you find out in-advertently so to speak.....................Sorry this was so long winded but I wanted you to get it right.....Mike
What are the "lot of reasons" it is unwise to shift at redline? Fuel economy is all that comes to mind and that is outweighed by the fun factor for many. As long as your oil temps (not just water temps) are up, redline shifts will have virtually no effect on engine life.
2015 F3 (wife's)
2014 Indian Vintage
2019 AMG C43 cabrio
1966 LS1 Corvette restomod
1956 Corvette survivor (wife's)
1941 Chevy hotrod truck
2023 Corvette Z06
ALL THE TIME AT REDLINE
Friend if you feel ( and I think you do ) that shifting at the REDLINE is the way to operate your ride ......there is nothing I can possibly say that will sway you from that thinking..........good luck & God Bless .......Mike
I do not feel that shifting at redline is the best way to operate our ride, and, in fact, it hasn't been to redline so far. But.....I don't see anything wrong with doing that if one so chooses. That's why I was curious as to the "lots of reasons" you say that it is unwise to shift at redline. Maybe there's a point I haven't considered. Members on forums often make statements that others believe until challenged. It has happened to me and I stood corrected. I'm interested in the facts and sharing them on the forum. If someone claims one oil is better than another; I need to know why. If there are many reasons not to shift at redline, I need to ask what they are. I don't really ride an F3, but am very interested in what I learn on this forum.
2015 F3 (wife's)
2014 Indian Vintage
2019 AMG C43 cabrio
2023 Corvette Z06
Originally Posted by Sandraleamay
Lots of reasons?
That's the phrase I questioned from post #9.
2015 F3 (wife's)
2014 Indian Vintage
2019 AMG C43 cabrio
2023 Corvette Z06
Not so enduro?
Originally Posted by Mike Ard
I would bet that there were other factors that also figured into the engine failures. When I was a kid my brother and I both got 125 cc Yamaha enduro's. I broke mine in the way my dad taught us and my brother took his out to see how fast he could make it go. His engine was toast before 3,000 miles while mine died at 16,000 miles.....not because of the engine either, the frame broke.
Just laughed a little, because the enduro was not so endurance.
2012 RSS (Wife's)
2015 F3S (Mine)
Originally Posted by Wildrice
Mike--could you repeat that I guess it might depend on how fast a another vehicle is coming up behind you :-) When I'm bird watching I shift 2500, freeway entrance 5000-6000.
Darrell
This is what I do. Generally, I aim to keep it above 3,200 RPM, I do go to about 5,000-6,000 RPM's getting on the expressway.
Your birds are probably faster than mine
This is a noisy engine---anywhere in the 2500-3200 shift point in a low cruising speed is fine. Riding through a residential housing area I prefer a lower rpm--but to each his own--increasing speed from 2500 rpm does not lug the engine. I ride my turbo Hayabusa below 2000 rpm in a residential area--& the stock red line is 10,800 or 11,200 on my re-flashed ecu. It's a personal choice that makes you feel comfortable.
Stay comfortable & ride safe...
Darrell
I just know when to shift based on sound.
2015 F3 (wife's)
2014 Indian Vintage
2019 AMG C43 cabrio
2023 Corvette Z06
Well written! RPM is situational and sometimes redline is the best choice for the situation.
2015 F3 (wife's)
2014 Indian Vintage
2019 AMG C43 cabrio
2023 Corvette Z06
Tags for this Thread
