Results 1 to 6 of 6
Thread: Fuse box
    Registered Users nightshift357's Avatar
    Jul 2015
    north Carolina
    Default Fuse box
    Hello to all,you name is Pete aka night shift. I have a 2015 RT limited. Trying to find the fuse box. The 12 volt plug in the trunk is not working . I assume it's a bad fuse. Any advice would be appreciated.
    Sent from my SM-G925V using Tapatalk
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by nightshift357 View Post
    The 2 fuse boxes are located behind the front trunk. They are accessed through 2 access panels located in the front trunk. In you owners manual it describes how to access them starting on page 151.
    Active Member NM Wrench's Avatar
    Apr 2014
    Albuquerque, New Mexico
    I think it is switched unless you move a fuse 1 position. Try turning the key on and see if it works. If it does them you need to move the fuse
    Sent from my VS990 using Tapatalk
    14 RT-S , Stock Large brake pedal White Pearl
    Jul 2015
    north Carolina
    I greatly appreciate the response. Thanks a million.
    May 2015
    Barryville NY
    Default not to be a smart ass
    Not to be a smart ass but you have to unzip the liner in the frunk to get to fuse boxes.
    Feb 2016
    It should be on the F6 fuse which is switched by the key. If you want it hot all the time, move the fuse from F6 to F7.
    2020 RT Limited , Marsala Red
