Hyway Pegs heat issue
I just installed a beautiful set of Lamonster web pegs on my ST. Limited. I got them adjusted to how I want them and went into town for a short ryde to try them out and run some errands. I have one issue. the right side exhaust fan is right by my foot and even in this 70 degree weather, it did not take long and my right leg started getting very hot. Any one else experience this and is there anything I can do to redirect that hot air?
Thanks in advance
Bill
2017 F3 Limited
Leg
I have the same problem with my right leg. Figured out it is the hot air going up my pants leg so I got a very small bungie cord
and "bloused" my pants as we use to do in the Army. Turns out that worked for me, now my pants get a little warm but the leg doesn't.
Honestly; what did you THINK would happen?
It's not like folks haven't complained about the heat output from that part of the bike before...
Sorry; I've got nothing on this one, except for some condolences...
Maybe I need a Snickers Bar this morning.
Snicker Bar?
2017 F3 Limited
There is a block off plate made for this problem. Also it is rather easy to make a block off plate. If you do block it off, make a couple of holes in the plastic underneath or remove it completely.
Originally Posted by AY4B
Snickers Bar?
Sometime, we get cranky, when we're hungry...
Looks like Marylin and I have a lot in common. Hot air traveling up our legs.
2017 F3 Limited
COPILOT is right on this one. Had the same problem on my 2013. Read again his post above. (no Snickers required)
Jack
2015 BMW R1200R LC
2014 RTL SE6 Pearl White
2012 RT-622 trailer viper red
2011 Polaris Ranger green
2016 Can Am Maverick
Spyderpops makes all kinds of Block Off plates.
Cruzr Joe
Thanks, please post a link of that block plate . Is there a spyderlovers sponsor that sells them?
2017 F3 Limited
http://spyderpops.com/
Harvey is a sponsor...
