Limp home mode
I am getting a check engine light, a message "Limp Home Mode". Also, the exhaust is really loud and there is a funny odor (No, not me).
I hate to ask what this is
Sounds like time to check exhaust gaskets
Have to agree...
you have the header gaskets and the Y gaskets as well as the muffler. Some have had the exhaust pipe crack. I would think it would be the header or Y gaskets to get that message. might check the o2 sensors as well...
2012 RS sm5
exhaust pipe crack!!!! on an F3??? have not heard of this happening before?
Surly not but if so how HARD are you riding??!!
2013 STL SE5 BLACK CURRANT
SpyderPop's: LED bumpskid
minispyder dash toy
Lid lox
KradelLock
Pakitrack
FLO (Frunk Lid Organizer)
BRP fog lights, trailer hitch
SENA 20S EVO
I ride moderately. But I do ride in the cold. Last time I rode it it was 20 F.
Also, I will have to have it towed, will Can Am cover the towing charge?
You need to pull up the error code and see what the error is. You may not need to have it towed. Limp mode allows you to ride it but at reduced rpm so as not to damage the engine. If you do have to have it towed you will need your BEST warranty card, it gives you the phone number to call for towing. They don't pay for a very long tow though. It is limited by $$ and they don't get you very far. I sent you a PM with instructions on pulling up error codes.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
I believe the current warranty allows up to $200.00 per tow. you have to call up front and get approval.
stebrock is correct, Can-Am Roadside assistance will cover up to $200.00. If you have Roadside assistance with your insurance, it will probably be better. Mine covers up to $500.00 per occurrence.
Rotten eggs?
If that smell is similar to Rotten Eggs, then the internal part of the Catalytic Converter has gone bad. When this happens, it tends to block the flow of the exhaust gasses also and will change the sound of the exhaust. Only fix is to replace it or bypass it.
2011 RTS (Sold to a very nice lady)
1998 Honda Valkyrie
2006 Mustang GT. Varooooom!
US Navy Veteran
SC Law Enforcement Boat Captain
CNC Machine Service Technician
President: Rolling Thunder SC1
Member: Disabled American Veterans, Rock Hill, SC
Member: American Legion
Experience is recognizing the same mistake every time you make it!
All of these posts are assuming that you have a stock muffler, if you have a non OEM muffler than its a whole new ballgame, possibly without any warranty assistance.
Cruzr Joe
My F3 is stock except for the lights. I am going to call the dealership. Thanks for all the advice.
Updated
Rogue Hawk, sorry to hear what's happened to your F3 and I hope the problem is resolved quickly by the dealer. Please keep us updated on dealer's actions to resolve issue.
2015 F3-S in Magnesium with Can Am red frame
Blue Ridge Windscreen
Heated Grips
Name of my F3-S - Sandra
Xmas present to me and from myself on 6/11/2015 - 02/09/2018
2019 F3-S Special Series in Liquid Titanium with Orange frame
Heated Grips
Signature Light with switch to turn it off and on.
Name of my F3-S - Pamela
Hope not another problem surfacing
I will, I dropped it off to iMotorsports yesterday. They said Can Am will cover the tow.
Well, its been in the shop almost two weeks. They say they are replacing the injectors and cylinder heads. They had to send the computer module to CanAm because there equipment could not find the 'Limp Home' error. It only has 8.5K miles on it. I hope this is not an indication of the units reliability.
I hope that they gave you a loaner bike.
I have over 11 k on my F3S so far no issues other than heat on the legs when it's over 90 degrees outside.
Good luck, please keep us posted.
2015 F3-S Pearl White SM6 with a 7 Jurock custom windshield, Smooth-Spyder backrest, Shad saddle bags, RT sway bar, Elka stage 2 shocks in front and stage 2 with hyd. adjuster in the rear. Lamonster's LED fog lights, TricLed headlights, TricLed Safety LED package.
Well, I got it back. They say it was an ignition coil. The reason it was a head scratcher is the computer was lying to them. First off, the F3 computer did not register the 'Limp Home' diagnostics. They consulted Can Am a few times, then finally send the computer to Can Am. When Can Am hooked it up, the computer said the problem was the number three ignition coil. They replaced it but the problem persisted. So finally they just did a process of elimination, replacing each coil and see what it did. It turns out the number one coil was bad. When that happens, the piston stops working and the F3 runs on just the remaining two cylinders. That is why the power was down and the noise was way up. There was no issue with the muffler or headers.
F3 HAL computer -> "I'm sorry, Dave. But I can't do that".
Happy
Its great to hear that you have got your Spyder back.
Heated Grips
Heated Grips
Ozzie Ozzie Ozzie
