GS Speedometer display acting up
went for a ride today and as I was riding the lCD display would go out and come back on did this several times the rest of the cluster the analog speedometer and tach would continue to work
the odometer would even continue to record mileage
any ideas on this issue
speedometer
your problem
...This sounds like a wiring or loose plug issue , but I don't know how it could be the plug, because some things still work .......Mike
when I had an 08 when the speedo reached 62500 miles it started over also when the hours got to 1060 it froze
the hour meter did the same thing on my 09
speedo
I'm close to the 67k but I was told I had the software update to keep that from happening
from what I hear about that it just goes to zero nit blanks out
speedo
well checked the connection on the gauge cluster clean and tight battery good connections tight
fired it up gauge worked fin for about 10 min then faded to blank
after i shut down and turned on after being off for a few min it was back then faded to blank quickly
the analog works fine but the digital LCD goes blank but does maintain recording information
is there another plug deeper that i might need to check ?
cluster
I had the exact same thing happen to my Cluster on my 2010 rt about a month ago..Did the same as you checked all conn. Batt was new with no problems there...Ending up changing the cluster all is well now...you might have to get dealer to sync new cluster to BUDS..By the way new clusters
are not cheap about 400.00 to 800.00 on Rt..depending if you go with new or used...
Freebob...
faded out
well last time i used it the display faded out and has not returned
A new cluster from BRP parts online for a 09 GS/RS SM5 is 349.00. Or BertsMegaMall is 369.00. Take it to dealer and tell them to pull a cluster from another bike and check it first before spending a couple of hours "troubleshooting" it. I done went this route one time before.
speedo
thanks ill do that actually have a friend local i can swap display with to see if issue moves since closest dealer is 150 miles
