I fixed my thermite mixer
I have a 2015 RT-S. I started to leave the house. Spyder started as usual, but halfway down the driveway the engine just quit. I tried to restart it but no joy. I didn't have time to play with it right then and there. The code P0000 was showing. I came back to it later in the day. I talked to a few people and I figured it must be the thermite mixer not working. Now getting to this item was difficult. I took two layers of tupperware off. I removed the windshield and the entire dashboard. Now this is where it got confusing because the owner's manual wasn't very clear. But I did what it said and removed the right front wheel and the rear drive wheel. Why, not a clue. Finally I removed the battery and somewhere down below i found the thermite mixer. I quickly saw the problem. Somehow the wires to this mixer got spliced into the brake light. I removed the brake light and I also removed the brake, why not. I rewired the thermite mixer. Well I got everything back together except for 5 or 6 pieces of tupperware, a few bolts and screws. I stepped back and looked at my Spyder and it looked pretty good. Except it was tipped to one side. Somehow I put a big wheel on the front right and a tiny wheel in the back I does sit lower. Oh yeah then there's the American Flag placed where the foot brake was located. But guess what, yup, it started right up. Rides a little rough.
Now can someone guess what was really wrong....Harvey Clark no telling
By the way, I did figure it out by myself!
Was there any ectoplasmic residue seeping from the thermite mixer?
2011 RTS (Sold to a very nice lady)
1998 Honda Valkyrie
2006 Mustang GT. Varooooom!
US Navy Veteran
SC Law Enforcement Boat Captain
CNC Machine Service Technician
President: Rolling Thunder SC1
Member: Disabled American Veterans, Rock Hill, SC
Member: American Legion
Experience is recognizing the same mistake every time you make it!
Was your gremlin bell working? Since you had to remove the right tire, a gremlin might have bit your Spyder from that side!
Hmmmm... sounds like the thermite mixer caused a stuck kanootin valve which makes the kill switch activate, and if not taken care of immediately it will make your muffler bearings go out in the long run!!!
Fluids
It is my humble opnion that the blinker fulid has run low and being that it's a few months old ---- it needs to be flushed and refilled.
Running low on blinker fluid can cause:::::::
Kaos
PS::: bumped the kill switch???
Sounds to me like a sure case of fuel in your gas tank OR exhaust gases leaking out of your muffler. When that happened to me, I fixed the issue by eating a large dish of ice cream.
2020- RT Limited
Chalk White, Can-Am rear passenger armrests, Comfort Seat, Grip puppies, RAM Cup Holders, Providence RAM Mount
FOBO2 TPMS
Aluma MCTXL trailer
BRP hitch
Big Bike Parts wiring harness
Permanent Smile!!!
Sounds like your left blinker fluid was low.
Cruzr Joe
I'm unable to make a determination of the problem because your story did not start with "But Honey, it was making this funny noise and then ..........". Had you included that, I would have known that it was due to the nitrogen you put into the tires.
2015 RT-S SE6 Red Pearl - aka "Ruby"
Tri-Axis handlebars - Bajaron Sway Bar and Heim Links - Roadster Renovations Spring Stiffeners & Top Case mirror - Value Accessories 3 pc. Lid Net Set - Lidlox Helmet Holders - JT's Dash Mount Bar - Drink2go rider & passenger cupholder - Wolo Bad Boy Horn - Show Chrome Trunk Rack - 12V power & heated gear ports - Spyderpops missing belt guard - BRP Trailer Hitch - Gold Plug hex head drain plugs
Did the repair start with "hold my beer and watch this"
Cruzr Joe
It's right next to the Gonkulator under the Kanifer Valve. That should take care of it.
You mite check the warp drive.
If I can't fix it, I will fix it so no one can fix it. Sypder Loco!
Thermite mixer
someone got it right. Yup I bumped the kill switch as I was heading down the driveway. As I approached the bike I said to myself, self could I have bumped the kill switch...yes I did
