Results 1 to 17 of 17
    Aug 2015
    Maricopa, AZ
    Default Removing drip pan
    It seems to me that I read a post saying that leaving the drip pan off not only made it easier to do routine maintenance but it also helped out with the heat problem. Has anyone done this and have you had any problems with rock or degree damage?
    Jul 2010
    Las Vegas, NV
    Default Belly pans
    Relocate them to a shelf in the garage! Useless. We are on Ann's 3rd Spyder, and all of them were belly pan free! We promptly remove them at the first oil change, and leave them off. Well over 100,000 miles; no issues. Makes oil changes a snap, runs cooler, works great! Joe
    Joe Meyer
    Aug 2015
    Maricopa, AZ
    Quote Originally Posted by cptjam View Post
    Thank you, they are a pain.
    Mar 2012
    NJ
    We've pulled them on 3 Spyders now and tossed them. Not only do they make oil changing easier, but the bottom of the motor, frame, etc stays cleaner with the debris trapping pans removed. Also makes periodic inspections easier since you can see too!
    Nov 2012
    North Las Vegas, NV
    Took them off our 2012RT, no problems.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Very Active Member Devious56's Avatar
    Oct 2015
    N.E. Florida
    Are these drip pans on all Spyders or just certain models?
    Thanks
    David
    How old would you be if you didn't know how old you were?
    Default Well....
    Many have removed them but if you feel better if they are there you can drill large holes in them as I did. 11/2" or so.
    ​2012 RS sm5
    Active Member 2RTsGV's Avatar
    Sep 2014
    Grain Valley MO
    Default What are they ....
    what are they?
    where are they?
    what do they look like?
    I love how the earth rotates around the sun ... it really makes my day!
    Currently Own:
    2019 F3 Limited - Vegas White (Dark Edition) - His
    (Baja Ron bar/links-Short reach bars-Center footpegs-Tall boy screen-Flag holders-LED Skidplate-Spydercuffs-Ultimate seat-LED Headlights)
    *** BLOWN MOTOR Apr 21 @3,800 miles, motor replaced by BRP Jun 5, 21 ***
    2019 RT Limited - Phoenix Orange (Chrome) - Hers
    (Baja Ron bar/links-Skidplate-Spydercuff-Comfort seat-LED Headlights)
    Previously Owned:
    2013 RT SE5 (Orbital Blue) *31,000 Miles* - His
    2012 RT Ltd SE5 (Pink Full Body Wrap) *41,000 Miles* - Hers
    2021 Ryker 900 (Black) Sport Windshield - Foam Grips - Solo Comfort Seat
    Mar 2012
    NJ
    Quote Originally Posted by 2RTsGV View Post
    what are they?
    where are they?
    Black plastic TV tray sized pieces that are mounted to the bottom of the Spyder. There are two of them, each one mounted right in front of your feet.
    Think of them as useless plastic skid plates. [emoji106]
    Sent from my Nexus 6 using Tapatalk
    Sep 2014
    Grain Valley MO
    Quote Originally Posted by DrewNJ View Post
    Thanks
    Currently Own:
    Previously Owned:
    On the 2010 to 2012 RTs; they're pretty easy to remove...
    I've been told that the 2013 RTs are a bit tougher...
    As far as the new 1330s:
    It doesn't seem to be as necessary to remove them, because there are no issues with under-bodywork heat.
    Jun 2010
    Las Vegas
    FlamingoBabe's husband, HotGlue, used on for a door handle on his screen door. He was going to make a water wheel with them but changed him mind. I must say they make a nice door handle.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Idaho
    Quote Originally Posted by BruceA View Post
    If you have a 2013 RT the heat recall modification adds a fuel vapor filter unit fastened to the right side pan. If you remove the right side pan you have to make alternate provision to support the filter.
    2014 Copper RTS
    SpyderLovers Sponsor spidergreg's Avatar
    Sep 2015
    Jamestown, KY
    Default So how do you remove these drip pans?
    I’m in the middle of my first DIY oil change on my 2012 RTS and have discovered that this drip pan is a problem! I have watched several videos on changing the oil, but none of them mentioned removing the drip pan (I’m guessing that they had already done it?). Anyway, I don’t see how I can get the transmission filter out without removing the pan. Any help on where and how this pan is attached to the bike would be helpful.
    Thanks in advance, Greg
    Greg and Debbie 2012 RTS
    Our Mods
    Idaho
    Both filters, engine and transmission, are on the left side of the engine. You need to remove the left lower tupperware to get to them. There's no need to remove the pan under the engine, but if you're not careful you can end up with oil spilling onto it.
    Look for Youtube videos on changing oil for 2010 to 2013 Spyders.
    2014 Copper RTS
    Sep 2015
    Jamestown, KY
    Thanks, had all tuperware on left side removed, but could not get the transmission cap through the opening. Found the two 10mm bolts holding the drip pan on and removed it, much easier to get cap and filter out. Oil change now completed.
    Our Mods
    Idaho
    Hmmmmm, interesting. I wonder if that's one of the changes in the frame from 2012 to 2013 when the 1330 engine was supposed to be incorporated into the Spyder. I never had to remove the pan from the 2013 RT I had.
    2014 Copper RTS
