Try tapping the edge of the bolt with a flat blade screwdriver and hammer or even an air tool if you have one.
2020 F3 Ltd
Spyderpops Bumpskid
Spyderpops Brake/Run/Turn Signal LED's
Lamonster Garage LED Fog Lights and Headlights
2013 ST-S retired 1/9/16 at 25,061 miles
2015 F3S sold at 77,565 miles.
SpyderLovers Founder
This is not uncommon and what works for me is to take a sharp chisel to the edge and tap it loose. Best if you warm the bike up first.
I have already tried that.Nothing
It's good to hear that I am not the first this has happed to. It really makes a person feel like an idiot. I will try a chisel.
RT-S PE#0060
best to use a small chisel, screw driver handle takes up too much of the shock
Agree...
A chisel with no handle so all blows are metal on metal. The shock helps brake up the varnish resulting from the hot oil baking on the threads. I always tap a few solid blows to the drain plugs to loosen that seal...
2012 RS sm5
Good luck, you'll get it out. When you do, switch to a Dimple Plug or Gold Plug.
otherwise be a vulgar brawl.
Cognac 2014 RT-S
We nearly had the same thing yesterday and we were really glad that our customer brought Dimple Plugs with him for replacement.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Unless you really know what your doing take it easy with the hammer. Never been to fond of hammering on an aluminum case.
Sent from my Nexus 6 using Tapatalk
I bought dimple plugs this past fall and putting them on this week.
Now That My 2009 was traded in with 35,000 miles I can admit mine got stuck the first oil change and I never got it loose. I changed All the other oil and that 1/2 quart left in the motor never caused me any grief. But I would also extract 2 quarts from the tank at 2,500 miles and refill - Then change at 4,500 miles!
Sea Doo GTI-SE 90 Jet Ski!!
small pipe wrench? the harder you pull, the tighter the jaws get. guaranteed to work.
Same thing happened to me on both plugs. Vise grips worked. There is enough thread to grab on to. The secret is to jack the Spyder up so you can see what you are doing, don't work blind what ever method you choose. Good luck!
Because the crankcase (alloy) and drain plug (steel) expand at different rates.
You can heat the area directly around the plug with a small torch, before grabbing
and removing pesky plug.
just warming engine won't do it, because that allows plug and crankcase to heat "together".
Flatlander, Navy Veteran, Widower
Loved my 2014 RTS SE6 Pearl white
but have a new love now,
my 2017 RTS SE6 Champagne metallic (Champ)
SpyderLovers Sponsor
Concur; a small propane torch can heat up the surrounding area, and let you get it out. You can file or hacksaw a slot for a flat tip screwdriver, or vise grips. Used in combination, that plug is going! Joe
Joe Meyer
They have tools that are made to remove rounded off bolts,screws etc and work really well. They fit over the rounded off head and grip to it when you turn.
Sometimes a little heat will help too.
What about an impact driver? Any reason not to try one?
2019 Black F3-T
