LED fender light strips
Installing LED light stripes on fenders of 2012 RT S .My question is anyone use 3M adhesive promoter ? Or will a good cleaning with alcohol be enough for good adhesion ? I have seen directions both ways.
On a smooth painted surface like the fenders; the alcohol cleaning method seems to work just fine.
It's when you mount them on a surface that isn't all that smooth, that the "promoter" starts to strut it's stuff!
Because it is out in the weather (especially in that area) the promoter would help.
Cruzr Joe
Thanks ,that was what I was looking for someone that has done it before.
Alcohol cleaning has worked good for all my decals. Fyi I find it best to let evaporate dry then apply whatever. If you can apply pressure to what you are sticking down for extended time also helps. Share pics if you can plz
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
Alcohol may be okay by itself but then my question would be; then why do Tric-LED and Custom Dynamics include 3M promoter with all of their lights?
Use the promoter, better safe than sorry.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
Have used both. The promoter works way better.
Sent from my SAMSUNG-SM-G920A using Tapatalk
2007 M109R LE - To many MODS to list. Its cheaper that way!!!
As I recall; Reggy's instructions mention using it on the dark plastic pieces on the bikes. For the painted stuff; he supplies some alcohol swabs.
alcohol prep is good enough just warm up the tape & area before applying
He supplies alcohol pads and 3M promoter with all of his lights
2010 RT- 622
