Results 1 to 5 of 5
    GreatFalls Montana
    Default Starting issue with a 2014 RT L
    I went to start my Spyder the normal way, and after pressing the starter switch it didn't even click or crank like the battery was dead. After releasing the brake and then attempting to start did it come to life. So Major Spyder tried starting his 14 RT L, It did the same thing.
    Just checking to see if anyone else experienced this.
    2014 RT L Lightin' LeeRoy
    1980 CM 400A
    1982 CM 450A
    [/SIGPIC]Lightnin' LeeRoy
    If you park your bike, and leave it in neutral; you don't have to apply the brake in order to start it...
    Besides; the engagement clutch Is disengaged, so leaving it in gear does nothing at all.
    Jul 2014
    Mint Hill, NC
    Have never had that happen. I have on a couple of occasions when bundled up for a winter ride accidentally bumped the kill switch, not enough to fully throw it but enough to break the circuit, and Spyder wouldn't turn over. Quick visual check showed problem.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    GreatFalls Montana
    The bike was in neutral, I just released the parking brake and it started when I pushed the switch.
    1980 CM 400A
    1982 CM 450A
    Vermont
    I have had that happen to me, but the" kill switch" was hit by mistake. My spyder was in "Neutral" and the spyder started. Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
