Page 1 of 2 12 LastLast
Results 1 to 25 of 29
Thread: Trunk lid fix
    Very Active Member GaryTheBadger's Avatar
    Jan 2009
    Northwest Arkansas
    Default Trunk lid fix
    Here's a two-minute fix that lets you open your Spyder's trunk one-handed. The spring slides tightly over the two nuts and stays put. Still allows one-handed lid drop-closure. Easy removal if you change your mind. Should have come from the factory like this.
    Enjoying now: 2015 Spyder F3 SE6, 1970 Indian MM-5A, 1972 Suzuki RV90J Rover, 2017 Indian Chieftain (wife's)
    Wish-I-had-kept-them: 2008 Spyder GS SE-5, 1967 Shelby GT500 w/Paxton supercharger, 1972 DeTomaso Pantera, 1991, 1992 & 2001 Acura NSX's, 2012 V-Star 950 Tourer, various 2-, 3- and 4-wheelers
    Jan 2009
    Northwest Arkansas
    Okay, so I'm not so smart. Apparently someone else already came up with this idea and posted it.
    At least it proves BRP should have designed it this way in the first place!
    Invalid Emails
    Nov 2007
    Victoria Harbour, Ont.
    Gary:
    So where did you get it? And what was the springs original useage?
    Thanks
    2faston3
    Registered Users Rando's Avatar
    Sep 2007
    Mesa, AZ
    I still think this is the easiest and best looking fix! Cut, bend and drop in place. No assembly required!
    Very Helpful Member bjt's Avatar
    Oct 2007
    Grand Blanc, MI
    Quote Originally Posted by garyberger View Post
    LOL, yep. You're still smart but you're a bit too late. I originally read about this type of mod around December 2007. Still nice to see different variations on it. Works great, don't it?
    Jan 2009
    Northwest Arkansas
    2FASTON3: The spring came from a bin of spare hardware I've been collecting for over 30 years of working on cars and bikes. No idea what it was originally for. Its nothing special. Places like Home Depot, ACE Hardware and Lowe's have assortments of springs, you should be able to find something.
    Alignment Specialist bone crusher's Avatar
    Aug 2008
    MD
    I have a thread on the general topic board that tells how to do this...it's a number 155 spring that can be found at any real hardware store (not Home Depot)...
    Bone Crusher
    If you work to make money, you'll never be happy, as there's never enough money...if you work to take good care of people, the money will always be there....Sean O'Connell, 1999
    Registered Users Biker's Avatar
    Aug 2008
    Allentown, PA
    I'm glad you told me what spring number it is. I went to Home Depot and picked up a bag of assorted compression springs but they were not strong enough to make the lid pop. Oh, it worked but not the way it should. I will try and find this size spring you suggested. Thanks.
    Registered Users Spydyr's Avatar
    Jun 2008
    Moundsville, West Virginia
    Quote Originally Posted by bone crusher View Post
    Bought spring #155 for $1.20 at hardware store and it fit perfectly, thanks.
    If you can't run with the big dogs, stay on the porch!
    Very Active Member smokster's Avatar
    Sep 2007
    Quote Originally Posted by bjt View Post
    To be a PE member and be old and wise
    Now I know how my parents use to think.
    One thing is constant, ride safe within your expertise level.
    Controlled caos for me
    Sep 2008
    Carmel, In
    Quote Originally Posted by Spydyr View Post
    +1 ACE Hardware. Works great.
    Aug 2008
    MD
    No problem...this is a really cheap fix and it works really well! I've had mine on for some time and it still 'pops' open nicely every time...the spring tension is the key and the 155 is perfect for our needs...
    Bone Crusher
    Aug 2008
    Allentown, PA
    Quote Originally Posted by Biker View Post
    Well after getting that spring number, I found it at Sears Hardware. It was perfect. Thanks again.
    Aug 2008
    MD
    Should not have a problem again! This is something that BRP should put on all bikes...only makes sense as what they do doesn't work!
    Bone Crusher
    Dec 2008
    Syracuse, NY
    Quote Originally Posted by Trickie Dick View Post
    Thanks for mentioning ACE hardware. Went there today and picked one up. I have to wait to put it on. My mechanic has the Spyder to install the (modified) Home Run package. I got the modified version because I have a BRP sport rack. I could have installed it myself; but, I'm doing my fair share to keep the economy going; plus sometimes I get a little lazy.
    Sep 2008
    Carmel, In
    Quote Originally Posted by wyliec View Post
    Well this is one tough install. Put a dab of silicone on, pop on the spring, close the trunk and voila! come out in the morning and turn the key and your trunk pops open. Even I handled this one.
    Dec 2008
    Syracuse, NY
    Thanks, I forgot about the dab of silicone.
    Sep 2008
    Carmel, In
    Active Member Kmort44's Avatar
    Jul 2011
    South Bend IN.
    Default Trunk lid spring#155
    I installed a Hillman#155 spring today and it works better than I would of ever guessed! Once again the SpyderLovers forum is worth it's weight in gold. Thanks for the mod!
    ​KMORT44
    Very Active Member MikeinGA's Avatar
    Jul 2011
    Mount Airy,Ga.
    Quote Originally Posted by GaryTheBadger View Post
    I have a 2011 Spyder RS-S and it came with the spring.
    Mike
    Quote Originally Posted by Rando View Post
    Rando,
    Could you please throw a few more details up here about this? What tyoe if spring did you use and how much cutting was needed?
    Thanks!
    Sep 2007
    Mesa, AZ
    What type of spring did you use...
    The type that would fit!
    Active Member Dtryke's Avatar
    Tucson
    Default Thanks
    Thanks for posting!! Great easy fix. $1.20 at Ace H/W!!
    Very Active Member Magdave's Avatar
    Jun 2013
    NE South Carolina
    Lowes sells a 3 pack of Hillmans including the 155 $3.69. I would like to hope to get one to work on the seat too.
    2013 Mag Silver SE5 RT BahaRon Sway bar & Sway bar links, Grip Puppies, Kuryakyn Helmet locks , Ultimate Seat w/Utopia Backrest, Dash power outlet, Spyderpops BumpSkid, Swagman Cup holders, Full size Brake Pedal, Seal DLX Floorboards, Freeway Blaster horns, Sylvania Super Bright fender LEDs, Scotchlite 680 Rear & Fender Reflectors, BRP Fog Light Kit, LED Mirror turn signal strips, 2014 RT grille mod. Outlaw Laser Alignment
    Registered Users eagleeye299's Avatar
    Jul 2013
    Leesburg FL
    Just picked up a #155 coil spring at my local "old time" hardware store. Cost $0.94. I love shopping there and try to as often as possible. Hate going to the home mega mart.
    2016 F3 Limited Triple Black
Tags for this Thread
