Trunk lid fix
Here's a two-minute fix that lets you open your Spyder's trunk one-handed. The spring slides tightly over the two nuts and stays put. Still allows one-handed lid drop-closure. Easy removal if you change your mind. Should have come from the factory like this.
Enjoying now: 2015 Spyder F3 SE6, 1970 Indian MM-5A, 1972 Suzuki RV90J Rover, 2017 Indian Chieftain (wife's)
Wish-I-had-kept-them: 2008 Spyder GS SE-5, 1967 Shelby GT500 w/Paxton supercharger, 1972 DeTomaso Pantera, 1991, 1992 & 2001 Acura NSX's, 2012 V-Star 950 Tourer, various 2-, 3- and 4-wheelers
Okay, so I'm not so smart. Apparently someone else already came up with this idea and posted it.
At least it proves BRP should have designed it this way in the first place!
Gary:
So where did you get it? And what was the springs original useage?
2faston3
I still think this is the easiest and best looking fix! Cut, bend and drop in place. No assembly required!
Very Helpful Member
LOL, yep. You're still smart but you're a bit too late. I originally read about this type of mod around December 2007. Still nice to see different variations on it. Works great, don't it?
2FASTON3: The spring came from a bin of spare hardware I've been collecting for over 30 years of working on cars and bikes. No idea what it was originally for. Its nothing special. Places like Home Depot, ACE Hardware and Lowe's have assortments of springs, you should be able to find something.
Alignment Specialist
I have a thread on the general topic board that tells how to do this...it's a number 155 spring that can be found at any real hardware store (not Home Depot)...
Bone Crusher
If you work to make money, you'll never be happy, as there's never enough money...if you work to take good care of people, the money will always be there....Sean O'Connell, 1999
I'm glad you told me what spring number it is. I went to Home Depot and picked up a bag of assorted compression springs but they were not strong enough to make the lid pop. Oh, it worked but not the way it should. I will try and find this size spring you suggested. Thanks.
Reason: grammar
Bought spring #155 for $1.20 at hardware store and it fit perfectly, thanks.
If you can't run with the big dogs, stay on the porch!
+1 ACE Hardware. Works great.
No problem...this is a really cheap fix and it works really well! I've had mine on for some time and it still 'pops' open nicely every time...the spring tension is the key and the 155 is perfect for our needs...
Bone Crusher
Well after getting that spring number, I found it at Sears Hardware. It was perfect. Thanks again.
Should not have a problem again! This is something that BRP should put on all bikes...only makes sense as what they do doesn't work!
Bone Crusher
Thanks for mentioning ACE hardware. Went there today and picked one up. I have to wait to put it on. My mechanic has the Spyder to install the (modified) Home Run package. I got the modified version because I have a BRP sport rack. I could have installed it myself; but, I'm doing my fair share to keep the economy going; plus sometimes I get a little lazy.
Well this is one tough install. Put a dab of silicone on, pop on the spring, close the trunk and voila! come out in the morning and turn the key and your trunk pops open. Even I handled this one.
Thanks, I forgot about the dab of silicone.
Trunk lid spring#155
I installed a Hillman#155 spring today and it works better than I would of ever guessed! Once again the SpyderLovers forum is worth it's weight in gold. Thanks for the mod!
I have a 2011 Spyder RS-S and it came with the spring.
Mike
What type of spring did you use...
The type that would fit!
Thanks for posting!! Great easy fix. $1.20 at Ace H/W!!
Lowes sells a 3 pack of Hillmans including the 155 $3.69. I would like to hope to get one to work on the seat too.
2013 Mag Silver SE5 RT BahaRon Sway bar & Sway bar links, Grip Puppies, Kuryakyn Helmet locks , Ultimate Seat w/Utopia Backrest, Dash power outlet, Spyderpops BumpSkid, Swagman Cup holders, Full size Brake Pedal, Seal DLX Floorboards, Freeway Blaster horns, Sylvania Super Bright fender LEDs, Scotchlite 680 Rear & Fender Reflectors, BRP Fog Light Kit, LED Mirror turn signal strips, 2014 RT grille mod. Outlaw Laser Alignment
Just picked up a #155 coil spring at my local "old time" hardware store. Cost $0.94. I love shopping there and try to as often as possible. Hate going to the home mega mart.
2016 F3 Limited Triple Black
Tags for this Thread
