Brake pedal pad
Can someone tell me how to remove the brake pedal pad. I see that there are two bolts on the underside of the pedal, but I cannot fit a wrench or socket in there to remove them.
A socket will work. It's a little tricky getting it on, but it will go on. If I remember right, it's a 10mm or 11mm socket.
Good luck.
What are you planning to do?
2012 Spyder RT SE5 Brake pedal mod
It's a 10mm...
A 1/4" drive works best in those tight quarters.
It's a 10mm...
Ditto. ^^^^^^^
Just replaced mine and collapsed the foot board for easier access.
Brake pedal
I plan to see if I can do a little "reengineering" to create a brake pedal that is wider left to right than the stock pedal. I find I turn my foot in to engage the brake pedal, and my toe kicks the body panel. A pad/pedal that is wider would allow me to simply raise my foot and bring it straight forward to engage the brake. I already have a pad and a piece of stiff metal to attach to the stock pedal bracket.
SpydermanCT
2010 RT-S SE5 Timeless Black PE # 794 ~ RT-622 Trailer ~ Can-Am Garmin 665 GPS ~ Elka Front Shocks ~ ESI Brightsides with Rips Kit ~ ESI RT Fender Tips Kit ~ Rear Brightsides ~ HMT Brake Light ~ Tricplate rear running / Brake LED's ~ ESI Mud Flap Lights ~ LED Day Runners ~ Right Side Inlet Covers ~ Street Magic Scuff Guards ~ IPS Key Cover ~ KewlMetal Kewlocks ~ Spyderpops Radiator Block Off Plate and Catalytic Converter Shield Set ~ Carbon Fiber Kit ~ Corbin Seat
SpyderLovers Sponsor
You will find several vendors who already
have larger brake pedals for your Spyder
right here on this forum
