Originally Posted by Yazz
If you feel the need for speed, go to Spyderfest and do some drag racing. There's a F3 class...
You go girl! Deanna
Gremlin Bell
SpyderPops Missing Guard Belt
Ultimate F3 Floorboards
Sway Bar with Links
Rolo Laser Alignment
Half Cover
2015 BMW R1200R LC
2014 RTL SE6 Pearl White
2012 RT-622 trailer viper red
2011 Polaris Ranger green
2016 Can Am Maverick
Just a little reminder, here in Arizona if caught going 25+ over the speed limit the state can confiscate your vehicle and drivers license. Eventually
you will get your license back but not the vehicle.
Jack
2015 BMW R1200R LC
I've heard it said, that the Badger is sort of like the Wolverine's little brother... but with an equal attitude!
I have only heard ONE successful story of a dog attacking a badger... and living!
Top Speed
Originally Posted by lilwill
Hello to all. I'm new to the forum and about to pull the trigger on a 2015 F3-S. Has anyone topped this motor out ? what speeds can it reach
The theoretical top speed can be easily calculated. If you can do 60mph at 3500rpm then your top speed would be 120mph at 7000rpm. This is a good estimate because factors such as wind and terrain will affect actual results.
Bootie-The Grievous Angel
2015 F3-S, ISCI Handbrake, F4 32" Windshield, Zumo 660 GPS, Sway Bar
The same top speed as my partners 2011 RSS 191kph, which equates to around 118mph. And we still had a lot of straight road ahead. That was before I put my Blueridge Screen and Xcreen on.
We now have His and Hers Spyders.
Current Spyder, 2015 F3 Steel Black, Passenger Backrest, Blue Ridge Screen with Xcreen Extention, Akrapovic Muffler, Attitude Handlebars, Blades front rims, RT Swaybar,
Her Spyder 2011 Magnesium RSS Sportrack and Backrest, Comfort Seat, Grip Puppies, 3.5 inch Riser Bars, Wespyd Signature Swaybar. Hindle Muffler, Godiva Screen, Hiway Pegs Can Am Panniers
Previous Spyders
2013 ST SM5
2011 RSS
2010 RS
That's pretty darn close to what Bootie just estimated...
top speed
Calculations may be correct but hitting max rpm in top gear may be very optimistic.
Nobody ever said anything about getting near the redline...
With the bike in gear; it'll spin to 8100 rpm...
(It's limited to 7500 rpm, if it's in neutral)
My bike hits 2800 rpm at 55 mph.
If we divide redline, by actual rpm at a given mph (8100/2800); it gives us 2.893
multiply 55mph by that, and it should give us an idea as to what sort of speed it would touch at redline.
2.893x55 = 159.115 mph
MOgang Member
You forgot to factor in "the wind resistance of a barn door," whose effect increase in conjunction with the velocity of said vehicle.
Joy
Very Happy Ryder... '09 Phantom and a '15 F3-S
If you don't slow down, they can't catch you..
If you don't give up, they can't win.
What a long strange journey its been.
Was the mustang on a chevrolet rollback? It's not how fast you can go is how long you can stay in the saddle.
top speed
OK Bob--run that calculation at 7500 rpm & bs me with the mph number... 6500 rpm would be approx 128 mph & that's optimistic mph.
You'd never see the 7500 limiter in action, if the bike is in gear...
But it would work out to a touch over 147 mph.
2015 BMW R1200R LC
Top speed
For a reality check people may want to look up the speed record for 3 wheeled motorcycles. Lot of these calculations mean nothing in real life.
My 2 cents worth,
Tip
Docdoru ran about 129 at Bonneville: a World record for a liter-class bike.
...On a turbocharged GS!
MOgang Member
Joy
F3 Top Speed
The theoretical top speed of any Spyder is easily calculated without endangering yourself or anyone else. Unless you have a slipping clutch the ratio of engine rpm to speed is fixed. So all you need to do is note the rpm at a lower speed, say, 60mph. If the rpm at that speed is 3500rpm then divide your red line (7500) by that number 7500/3500 = 2.143 then multiply your speed (60mph) by that number 2.143 x 60 = 128.57mph.
The other way to do this would be to note your speed (in mph) at 1/2 of the red line rpm (3750) and multiple that speed by 2.
These methods would give you the theoretical top speed. Whether you can attain that speed depends on many factors including wind, terrain, drag, etc...
Who actually care's!
Jack
2015 BMW R1200R LC
MOgang Member
Has anybody heard from his recently?
He hasn't been in here for over two years...
Think he's into the GG Taurus now. Zoom zoom!
Joy
F3 Top Speed
Here are the Numbers Regarding Top Speed of the F3S. These are the theoretical numbers based on the gear ratios given in the service manual.
Max Engine RPM is 7500
Rear Tire Diameter is 23 inches (+/- 1/4in)
Gear Speed(mph)
1st 45.38
2nd 59.47
3rd 73.56
4th 88.20
5th 104.48
6th 123.52
These are the maximum speeds attainable in each gear.
There is some measurement uncertainty in the diameter of the rear tire which will affect the speed numbers slightly.
This assumes you can get up to 7500rpm in 6th gear and you probably can't due to wind and drag.
