Cruise Control Issue
There have been quite a few times, actually 90% of the time I try to set the cruise control it does not take. When it does set if I try to adjust the speed down it shuts off if I increase the speed it works fine.
Any suggestions, other owners experience this?
2013 RT-S SE5
I would have the dealer check it.
It should turn off if you
A - turn the switch off
B - touch your brake
C - change gears
D - activate the nanny
Cruzr Joe
C - change gears
Cruzr Joe
But have also found it will not engage if RPM too high, anticipating a shift. After I shift it will go right on to normal. (Mine is on the 998, i try to shift last min). Also pull up on brake pedal make sure your not brushing with foot might act quirky on bumpy road.
2013 STL SE5 BLACK CURRANT
SpyderPop's: LED bumpskid
minispyder dash toy
Lid lox
KradelLock
Pakitrack
FLO (Frunk Lid Organizer)
BRP fog lights, trailer hitch
SENA 20S EVO
Cruise Control
If your cruise won't set it may be due to a sticking brake light switch. If the switch is sticking, your brake light stays on and the cruise control won't set. You might have your dealer check the switch.
2020 F3 Ltd
Spyderpops Bumpskid
Spyderpops Brake/Run/Turn Signal LED's
Lamonster Garage LED Fog Lights and Headlights
2013 ST-S retired 1/9/16 at 25,061 miles
2015 F3S sold at 77,565 miles.
The cruise also doesn't like to set if the engine is pulling hard like going up a hill or accelerating.
2014 Copper RTS
Ozzie Ozzie Ozzie
It also won't set if your revs are too low for the gear you're in.... And if you are just on/above the minimum revs & you try to slow your set speed down any, it'll just turn cruise off!! For my 2013 RT, the min revs in the lower gears are a tad over 4000 rpm.
Exactly what I was thinking, too - what speed are you going, and what gear are you in when you experience this. The cruise control won't work if the RPMs are too low.
"Topper" is my Pearl White 2013 RT-LTD
Professional Retiree - liked it so much when I retired from the USAF, that I started another career so I could do it again!
Happy to be a member of the Maryland Spyder Web - find us at
http://www.meetup.com/MarylandSpyderWeb/
Good Advice, I will check the brake pedal next time I go out.
I generally only try to set it on straight runs, typically level but thanks.
The revs could be an issue. I am used to riding a vulcan 1500 with loud pipes and not used to the whine of the engine so I am normally running with lower revs. Although I do like to hear her scream once in a while.
If 13RT YOU HAVE THE 998 needs higher rev's. Cruise will not engage under 3300 fyi
minispyder dash toy
Lid lox
KradelLock
Pakitrack
SENA 20S EVO
I tried repeatedly to set the cruise and the dash would show the cruse is off, I would push it on try to set it again and it would show off. Finally when I was in second and accelerating with a high rpm it set. Appears the issue may very well be the low rpm's. After that I set is quite a few times in 2nd and 3rd generally around 4400 rpm. thanks.
Well 4400 is above the 3300 i stated. But I also said if rev too high anticipating a shift it will not So range is 3300-7700rpm i guess hope this helps
minispyder dash toy
Lid lox
KradelLock
Pakitrack
SENA 20S EVO
For the health of the engine you need to keep it above 4000 as much as possible. Nanny keeps track & the tech will chide you during the next checkup if you run it under 4000 a lot.
2014 Copper RTS
