1330 OIL DRAIN PLUGS
I will be picking up my new 2015 F3S next week and wanted to order some aftermarket hex head drain plugs for it when I do my own oil changes. I notice in the owner's manual there are two drain plugs. The goldplug.com website lists only one replacement hex head drain plug. On my former ST-S with the 998 engine, I had to order two different size drain plugs. Are the two drain plugs on the 1330 engine the same size?
2020 F3 Ltd
Spyderpops Bumpskid
I bought the Goldplug items for my 1330. I had the Goldplugs on my 998 also. It turns out, one of them is the same one needed on the 998 but there is a 1330 specific for one side. Not sure which is which from senior memory.
2015 an Am Spyder RT Limited
2013 Yamaha WR250R - Sold
2011 Can Am Spyder RT-S SE5 Limited - Sold
2011 Aspen Sentry Trailer
2003 BMW K1200LT - Sold
2007 Unigo Trailer - Sold
2001 BMW K1200LT - Sold
2001 Honda 750 NightHawk - sold
2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
Try this..
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
Here are two sources.
Dimple, both plugs: http://magneticdrainplugs.co/canamspyder.php
Gold Plug clutch cover (transmission): http://goldplug.com/shop/mp01/
Gold Plug crankcase: http://goldplug.com/shop/mp18/
I too bought the Dimple plugs. They are clearly superior to OEM. (Not knock OEM because I know they're made to a price point, etc) and are about the best magnetic drain plugs I've ever seen.
2020 RTL SE6
Get the Dimple plugs, they have the strongest magnets.http://magneticdrainplugs.co/canamspyder.php
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
Originally Posted by Highwayman2013
And a metric 13 and 14 socket fits.
Two Wheelers from 1963-2011
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
2022 RT current ride(silver)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
I agree with most of the other posters. Go with the Dimple Plugs.
Be careful, you'll need to salvage the O rings off the old plug and transfer them to the new plug, or make sure you have new O rings available.
IBA #47122
2020 RT Limited Asphalt Grey
I will add my for the Dimple Plugs!
Worth every cent !!!
How much metal on you picking up on the oil tank versus the trans plug with the magnetic plugs on the 1330? I know the stock trans plug has a magnet on it from stock
SpyderLovers Sponsor
Dimple
Work properly. Buy new o rings, swap out with the next oil change. The OEM drain plugs are horrible! Terrible design, fail easily, useless.
Joe Meyer
Pragmatic Member
I'll be ordering the dimple plugs for my next oil change which is due in about 7,000 miles (three months). Thanks everyone for all the positive comments and good information.
Pam
- 2015 RT-S Special Series / Red & Black
- Baja Ron Sway Bar
- Utopia Backrest
- F4 Customs tall and wide vented windshield
- Stebel Super Loud Air Horn
- Baker Built Air Wings
- LaMonster Highway Pegs
- SpyderPops Exhaust Block Off Plate
- SpyderPops KOTT Grill
- SpyderPops Belt Guard
- Cat Bypass
- Laser Alignment by Squared Away
- TricLED Fender Lights
- General Altimax RT43 rear tire
- Dual flag holder
- Mud Flap
- A$$hole seeking missile system
Ditto on the Dimple plugs recommendation. Very strong magnetic pull.
Enjoying now: 2015 Spyder F3 SE6, 1970 Indian MM-5A, 1972 Suzuki RV90J Rover, 2017 Indian Chieftain (wife's)
Wish-I-had-kept-them: 2008 Spyder GS SE-5, 1967 Shelby GT500 w/Paxton supercharger, 1972 DeTomaso Pantera, 1991, 1992 & 2001 Acura NSX's, 2012 V-Star 950 Tourer, various 2-, 3- and 4-wheelers
Drain Plugs
I've never encountered a drain plug requiring the allen socket. The 6mm socket in particular seems a bit sloppy and I am worried about stripping it out if I put too much pressure on it. Has anyone had a problem with removing the original plugs? I have the Dimple plugs already to install. They look awesome.
Thanks,
Ken
Where are you putting the 6 mm Alllen head? That's clutch cover plug, aka transmission plug. Crankcase plug is T45.
On my first DIY oil change after dealer 3000 mile service both my plugs came out perfectly and there was no indication on them that the dealer tech had a problem on his first try on the bike.
Thank you sir, I knew someone would help me out. The T45 was what I was looking for. All I could find prior to this was two sizes 4mm and 5mm. I haven't been able to get it up high enough to see what I was doing and was just going by feel. I've got that cleared up now so will be glad to have real hex heads to work with.
Magnetic drain plugs choices
I see the same sizes for both drain plugs on EBAY & Amazon for $9.95 Each=--one with free shipping. $63 for 2 drain plugs seem high priced/ Over the years I've see stripped threads on the crankcase due to over torque. Am I missing something on this $40 difference for 2 drain plugs--drain plugs are usually not a high usage item--every 5K to 7K miles . & nobody sees them except the mechanic. Please advise.
Thank you kindly,
Darrell
sizes
Thank you kindly,
Darrell
.......OK, what are the sizes and maybe we can figure it out,, the 998 and 1330 have different ones .......PS, I just bought the GOLD PLUG brand, and am very impressed with the magnet ( 1330 engine )....paid $ 24.00 delivered
Does anyone know the thread pitch on the Transmission side drain hole on the 1330 engine? I was told that it is 1.25. But I saw a reference to a gold plug that was the correct size 12MM but the thread pitch was 1.5. I am looking to replace the OEM plug with a Gold Plug but Gold plug seems to have only the engine side plug.
What is the difference between dimpleplugs vs the sho chrome plugs that lamonster sells besides price?
Greetings from Idaho
2014 RT-S,
Barjaron swaybar, chome luggage rack, Ram Mount GPS, 12 volt dash outlet, spyderflap mudflap, Rivco flag mounts, drink2go and custom handlebar drink holders,Driver Backrest,Tri-Axis Handlebars, TRICLed turn signal lights. Custon Dynamic Magic Strobe Brake Modulator, Triple Dash Pouches, "Squared Away" Laser Alignment, Spyderpops Bumpskid, TricLed "Knightrider" LED
2014 RT , White (Mine) Cognac (wifes)
M12 X 1.5 according to the parts list for MY 2014 SE6, and BRP has not changed the size. Find it in the fiche for Clutch Cover.
Gold plugs have both engine and oil. www.gold plug.com.
Amazon.com-
Gold Plug MP-01 Stainless Steel Magnetic Drain Plug
Sold by: Gold Plug LLC
Can-Am 1330 ACE Engine Magnetic Drain Plug – MP-18
I had very little on the OEM trans plug magnet when changed at 2K. Swiped with a rag and it was clean. Personally, I can see no reason to change that one.
Three Wheelers:
2011 RT(Red)
2014 RT(white)
2016 F3T(red)
__________________
2016 Slingshot
2018 Vanderhall
2019 Slingshot
The whole issue probably never would have arisen if BRP had specified the same type of plug, Torx or Allen, for both plugs. OTOH, a manufacturer is well within its rights to expect DIYers will check to see what type of bit is required before stuffing a bit in a hole they do not carefully examine beforehand.
