Page 1 of 2 12 LastLast
Results 1 to 25 of 32
    Active Member Biosafena's Avatar
    Jan 2013
    Northeast Ohio
    Default General Altimax tire question
    I have searched and read until I am almost blind, but can't find the answer to my question. I see that many people are using the General Altimax RT43 tire as a replacement for the rear. Does anyone have any experience with the General Altimax HP tire for the rear?? I know it costs a few dollars more, but I like the looks of the tread pattern. Any reason why the RT43 is more well suited for the Spyder than the HP model?? Thanks for your input.
    Sent from the corner of walk and don't walk...
    Default RT43 VS. HP
    I recommened this tire here. My GF Deanna has it now and she really likes it.....I have driven Hers and I think it holds the road well and it feels great......The difference is the RT is the newer model of the Altimax line .....Some changes were made to improve an already good tire....It still has the best rating of about 15 tires in this size ...215/60-15...........Hope this helps you out ....Mike .....I know they have a matching tire for the front ( 175/65-15 ) but you can check TIRERACK.COM and see if they have it in 14 inch size.!!!!
    Nov 2012
    North Las Vegas, NV
    I'm running the Altmax HP's on the front of my 2012 in size 185/60/14 they fit and work fine. If I was getting tires right now I would get the same size in an RT-43 because it is rated better all around. I would also run one on the rear in size 215/60/15.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Very Active Member jtoro1's Avatar
    Feb 2013
    port st lucie fl
    I am using the general RT in the back I like it ,I don't know if you could get the HP for the rear if I could I would use that one I got HP in the front they work awesome
    Vermont
    and the General Altimax RT43 tire that I have on the rear of the spyder, handles great on dry, wet, dirt, gravel, roads.
    ( mileage on the General Altimax RT43 rear tire is:4,496, and the total mileage on Spyder is 10,320 in hibernation, I replaced the original rear tire Kenda, It had 5,824 miles)
    The spyder hugs the corners great, and no problems with the nanny. I am running 26 psi.
    The tire rides very smooth. In the future if I need an other rear tire, I would get a General Altimax RT43. Blueknight911( mike suggested this tire because of the ratings it has) Good luck! Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Active Member cyclekid58's Avatar
    Sep 2014
    Post Falls Idaho
    I too have the General Altimax RT-43 in the back and have had no issues with it and seems to handle fine whether dry or wet, have not tried it in the snow but don't plan to. My question is what size fits comfortably in the front without being too tight fitting under the fender to replace the stock tire on my 2014 RT-S. I have looked at Federal Evo, and have thought about the general since I have had good luck with the rear.
    Greetings from Idaho
    2014 RT-S,
    Barjaron swaybar, chome luggage rack, Ram Mount GPS, 12 volt dash outlet, spyderflap mudflap, Rivco flag mounts, drink2go and custom handlebar drink holders,Driver Backrest,Tri-Axis Handlebars, TRICLed turn signal lights. Custon Dynamic Magic Strobe Brake Modulator, Triple Dash Pouches, "Squared Away" Laser Alignment, Spyderpops Bumpskid, TricLed "Knightrider" LED
    2014 RT , White (Mine) Cognac (wifes)
    Vermont
    Quote Originally Posted by cyclekid58 View Post
    I am also thinking of running General Altimax RT 43 on the fronts to replace the stock tires on my 014 RTS-SE6, ( current mileage on my front tires is: 10,320) Deanna
    Gremlin Bell
    Sway Bar with Links
    Half Cover
    Oct 2013
    rome new york
    Have the original kendas on mine. Have over 12000 miles on them prob. could get another 1000 but will change in the spring. Haven't decided what to put on.
    Been watching the post
    Registered Users HVACR Guy's Avatar
    Mar 2015
    Oakville,Ontario Canada
    Anybody else have the dealer complain that getting the 215 60 R15 tire to seat on the stock rim because it is narrower? I suggested tourniquet to pull the tire closer to the rim.
    Sent from my Nexus 6P using Tapatalk
    Nov 2012
    North Las Vegas, NV
    I had a car place mount my 215/60/15. They had no trouble.
    2016 F3 Limited
    2019 Ryker Rally
    2020 CSC TT 250
    Default TOO FUNNY
    Quote Originally Posted by HVACR Guy View Post
    .....Friend, the problem is with the Dealer not the TIRE. I've had 2 of these and one, 205/60-15 mounted on the Spyder rim by a car tire installer and they said NO PROBLEMS...........Also I doubt the Dealer actually does tire installs.........Mike
    Mar 2015
    They are using the ratchet down band to try to seat it on rim. I am the first "of course" to bring in a car tire to them. Early adopter has to suffer a bit.
    Mar 2015
    Hey Mike. Question from the dealer was why go with 215 60 R15 instead of 225 60R 15? 225 is stock size and goes on rim much easier.
    Default WHAAAAAAAAAAAT
    ................Like I said ..Dealer problems ..............using a RACHET STRAP !!!!!!.......are they mounting tires by hand ????....... I'm fearful of most dealers , but yours I would be TERRIFIED OF ..............Mike
    Active Member ssmcclub's Avatar
    Apr 2013
    massapequa ny 11758
    Default new general altimax rt 215/60/15
    new general altimax rt43 215/60/15 best rated rear tire for all year can am spyders paid $87.00 for it selling for $50.00 never use still has tags on it, pick up only I live in massapequa ny 11758 in long island sold
    richie spyder
    Mar 2015
    Well, all done and they got the new tire Installed and got steel valve stems from Lamonster installed at the same time. Tire rode smooth and of course hard rains on the way home to test the new tire. The dealer does very good work on everything I've gotten so far just got thrown a curve ball with the car tire. Will still go back to them.
    Very Active Member AbNormy's Avatar
    Apr 2012
    SW Austin
    Mee too Discount tire even prorated my Michelin defender charged my $68 mounted not balanced
    Norm H Austin Tx
    2012 RT A&C bought new 42312 sold July 2018 56k miles currently driving a 2014 RTSE6 LTD bought October 2018 w 6800 miles nicely farkled
    2014 RT SE6 LTD , White
    Very Active Member KX5062's Avatar
    Aug 2012
    Central Coast, CA
    Yes. (No dealer locally, but with 2 different tire shops that did not have a ratchet strap around, nor did I at the time.) It was finally accomplished by a tire shop that has a rapid inflation device that dumps air into the tire almost instantly, thus popping the bead.
    2020 RTL SE6
    Mar 2015
    I will try to remember this after hopefully 20,000 miles when I have to replace this new tire. Thanks for your input.
    Jax Beach, Fl.
    So why do you use the 215-60-R15 instead of the stock size 225-60R-15 tire on the rear?
    2014 RTL-SE6 Cognac (Current Love)
    2012 RTS-SE5 Pure Magnesium Metallic (Pre Loved)
    Pragmatic Member Pampurrs's Avatar
    Mar 2015
    San Tan Valley, AZ
    Quote Originally Posted by A1A View Post
    The General Altimax doesn't come in 225/60/15, but the General Altimax RT 43 in 215/60/15 fits just fine.
    Pam
    • 2015 RT-S Special Series / Red & Black
    • Baja Ron Sway Bar
    • Utopia Backrest
    • F4 Customs tall and wide vented windshield
    • Stebel Super Loud Air Horn
    • Baker Built Air Wings
    • LaMonster Highway Pegs
    • SpyderPops Exhaust Block Off Plate
    • SpyderPops KOTT Grill
    • SpyderPops Belt Guard
    • Cat Bypass
    • Laser Alignment by Squared Away
    • TricLED Fender Lights
    • General Altimax RT43 rear tire
    • Dual flag holder
    • Mud Flap
    • A$$hole seeking missile system
    Well the stock size is actually...................225/50 -R15 ................Mike
    Aug 2007
    Greeneville, TN
    Picky-Picky! I think I'll try a 235-45-16!
    Jax Beach, Fl.
    Okay folks,
    Thanks for your response's and the crux of the matter. Running a General Altima RT 43, 215-60-R15 on the rear. Which makes the speedometer read more correctly. Longer lasting tread wear and the same smooth ride and handling of a 2 ply tire, correct?
    Jul 2013
    peru, illinois
    Default Altimax?
    Hello All, Will this tire fit a 2012 Rss? Thank you. John
