FOBO tire pressure monitoring system
Understanding the system is key to getting it correct the first time. I down loaded the FOBO for bikes to my iPhone. Then I activated the system via email. But then the fun started. When you first start out there is a picture of a two wheel motorcycle and it asks you to confirm. I thought that it was just an icon telling you that this FOBO was for motorcycles, ah no! You must slide that picture till you find a CanAm Spyder icon which they call a reverse trike. But I didn't do that. So when I initialized the system all it would let me do was the rear tire and one front tire, ARGGGGGG! I added the correct icon, CanAM to the mix but to late I had told the system that it was a two wheel system. Changing that was a bit hard, as Lamont said us old guys just don't understand the modern world. So after talking with Lamont and following his lead I was able to eliminate the two wheel configure system. This allowed me to finally get all three wheels initialized. System runs perfectly. So thank you Harvey Clark, Jimmy and Lamont for taking he time to help out this old man with new world toys.
I have 5 FOBO sensors
I have 5 Fobo sensors - 3 on the Spyder and 2 on my trailer. I've used the Big Bike Parts TPMS and I like this better, partly because I found it difficult to mount the BBP display in a place where I could see it.
This gives me near constant tire pressure and temperature readings, alarms when needed and it seems to be quite accurate. I already had a RAM X-Grip where I can see my phone.
Having experience a flat tire on a 2-wheeler a few years ago, I consider this a must have.
2020- RT Limited
Chalk White, Can-Am rear passenger armrests, Comfort Seat, Grip puppies, RAM Cup Holders, Providence RAM Mount
FOBO2 TPMS
Aluma MCTXL trailer
BRP hitch
Big Bike Parts wiring harness
Permanent Smile!!!
Never had that issue, but.....
If you click on the "Settings" icon on each bike, you can release the sensors (you might have to scroll up to make that happen). I'd do that first and see if allows you to re-use them after that. I'd try to release all the sensors, delete the bikes (in that order) and start again. If you don't get a good response after that, you can go to this website and ask a question: http://www.fobobikesales.com/index.p...roller=contact.
Good luck, and please post the final chapter on this after you get it.
2020- RT Limited
FOBO2 TPMS
Aluma MCTXL trailer
BRP hitch
Permanent Smile!!!
Here is my problem, sent them a message...
I recently purchased 2 sets of Fobo for Trike. Install was a breeze. After only two days one of the sensors on my wife's bike (on fobo shared to my phone) shows battery needs replaced, all other 5 show full green. I installed a new battery, which I checked with a digital meter (3.66 volts) prior to installing, and now only shows two bars on battery. Is there a procedure that I need to do or could the sensor be defective in your opinion? Thanks in advance-
Their reply:
Dear Sir,
Thanks for contacting us.
Please take note, our app do some averaging over few cycles to show the exact battery level, if the battery indicator is showing two bars, three bars or red bar and the batteries are not old then don't worry the battery level will go back to normal.
Please don't change the batteries keep using the batteries. Let us know if you face any issue because of low battery.
Note: Battery voltage will drop when cold, but it will still work if there is sufficient capacity, and if parked in a garage, it will improve. However you'll notice fluctuation in the battery indicator bars during winter season.
Yep, that's the key. If you run into ANY problems during installation that you cannot get around, the fastest way to correct it is to release all the sensors and then delete the bike profile (in that order), and then start over. It only takes a few minutes and will save you a lot of trouble trying to figure out what went wrong. It is crucial to remember to release the sensors before you delete the bike profile, since identifying information about your sensors are also stored on FOBO's server. (If you fail to do that, the user guide has instructions about how to recover from that problem.)
HERE is a link to the user manual. It's rather hard to find online, for some reason.
FOBO SENSORS
I received a set of FOBO sensors from my friend, Leslie. So excited that I can just check out my tires from my phone now!
It's awfully nice. The back tire on the RT is such a pain to get at that it's worth it just for that tire!
2020- RT Limited
FOBO2 TPMS
Aluma MCTXL trailer
BRP hitch
Permanent Smile!!!
RT Spyder FOBO Tpms
robmorg,
Thanks tremendously for your assistance! You and OverHillAndDale have been very helpful! I went in and reread the instructions in the FOBO Guide 5.6 Release and Uninstall FOBO Bike. I had to reinstall the once sensor that I previously disabled and placed on the second bike. Once it was reactivated, I released it and then installed it onto the original bike that I skipped because it would not pair. Once it paired I was then able to completely delete the second bike I had created trying to pair all three sensors! Finally all on one bike and good to go!!!!!! I really appreciate this forum!!!!!!!!
You'll enjoy how well these things work. I bought a 2nd set for my trailer.
2020- RT Limited
FOBO2 TPMS
Aluma MCTXL trailer
BRP hitch
Permanent Smile!!!
