Page 2 of 2 FirstFirst 12
Results 26 to 36 of 36
  1. #26
    Feb 2019
    Portland, Oregon
    I am quite fond of Speed Bleeders as they make that job ridiculously simple and a solo act to boot. Anyone here ever try them on a Spyder?
    http://speedbleeder.com/
  2. #27
    SoFlo
    Get a quote from another shop. Those that have tried on their own, with experience of properly bleeding brakes, have done far more harm and expense than if they simply paid to have the task accomplished.
  3. #28
    SoFlo
    Downside of Speedbleeders is any compromise at the threads, that allows the entry of air, creates issues to obtain a proper bleed. With the amount of fluid needed to be pulled through the entire system, vacuum bled, done correctly works very well. Vacuum bleeding is also primarily a single person task, however I do complete every vacuum bleed with a few pump type bleeds at each bleeder fitting as the final bleed before topping up the reservoirs.
  4. #29
    Mar 2015
    forrest above Reno, Nv
    I have the Speed Bleeders on my V-Max and they seen to work perfect. Good, tight lever every time. I draw out most of the old flluid from the resivour with a turkey baster first then add new fluid . Rince and repete. Job done. I may get them for the Spyder. Thanksgiving turkey tastes funny though.
    Lew L
    2014 RTS , Circuit Yellow
  5. #30
    Feb 2019
    Portland, Oregon
    Sounds as though you have not used Speed Bleeders. They have a sealing compound on the threads that prevents air from passing and a check valve that allows only the outward flow of fluid. I have never experienced such firm brakes until I started installing Speed Bleeders. At $7 a wheel, they are a bargain.
    I'm looking for someone who HAS put Speed Bleeders on their Spyder and what they have to say about doing the job?
  6. #31
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    my speed bleeder was my wife.
    [joyce & irvin toms]
  7. #32
    Feb 2016
    I have BUDS and used it to flush my system at the 2 year mark (15 RTL). Following the BUDS procedure, the fluid that came out of the ABS module was much darker and dirtier than what came out of the calipers. Without BUDS, I'm not sure that all that fluid could be changed, since BUDS is the only way to get the ABS module to activate. Dark colored DOT 4 is an indication of absorbed water. Absorbed water will cause corrosion. Corrosion can cause an ABS failure. ABS module is expensive. Since it's only required every 2 years, I think it's a reasonable thing to have done properly to avoid what could be a far more expensive repair later, or worse, a collision in the event of an ABS failure. JMHO
    2020 RT Limited , Marsala Red
  8. #33
    Nov 2012
    North Las Vegas, NV
    You could lock your brakes a few times on a slippery parking lot, have the ABS kick in and then bleed them conventionally.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
  9. #34
    Oct 2014
    Fort Mill, SC
    What page in the manual is that procedure?
    1998 Honda Valkyrie
    2006 Mustang GT. Varooooom!
    US Navy Veteran
    Member: American Legion
  10. #35
    Mar 2020
    North Carolina, Fayettville
    Any one have a problem where break indicator light stays on after you release the breaks. The breaks will release and lock, when I turn bike off it beeps as if the breaks are not on even though the breaks are locked
  11. #36
    Oct 2014
    Fort Mill, SC
    Quote Originally Posted by Harrison55 View Post
    There's a micro switch down by the parking brake motor. It probably needs adjustment.
    1998 Honda Valkyrie
    US Navy Veteran
